Swapping the GSR intake valves with the ITR intake valves ?
Old Jun 14, 2002 | 09:31 AM
TRuST's Avatar
Default Swapping the GSR intake valves with the ITR intake valves ?
Does anyone know if the ITR intake valves flow better than the GSR intake valves ? I know that there lighter but I was read up on them and according to what I have read the ITR valves have a better flow pattern or cone than the GSR valves. My question is this true ?
Also, if I do swap out the valves will I be able to just drop them in or would need to do some machine work to clean up the valve seats ?
Old Jun 14, 2002 | 11:46 AM
sgT's Avatar
sgT
Default Re: Swapping the GSR intake valves with the ITR intake valves ? (TRuST)
You need to have a valve job done due to the differences in seat angle
Old Jun 14, 2002 | 11:47 AM
Ausmith's Avatar
Yes - the valve stem on an ITR is different than the GSR.
Old Jun 14, 2002 | 11:50 AM
TRuST's Avatar
Thanks for the info guy
Old Jun 14, 2002 | 02:31 PM
AK94GSR's Avatar
Anyone know how to tell the difference between R valves and gsr valves? are there any markings or anything
Old Jun 14, 2002 | 02:44 PM
sgT's Avatar
sgT
Default Re: Swapping the GSR intake valves with the ITR intake valves ? (AK94GSR)
intake valves are deshrouded
Old Jun 16, 2002 | 02:32 AM
GZR4DR's Avatar
Default Re: Swapping the GSR intake valves with the ITR intake valves ? (sgT)
30% lighter, you will notice that the valve near the base is much thinner compared to the GSR. Allows for slightly better airflow.
Old Jun 16, 2002 | 10:48 AM
LeftCorner's Avatar
Default Re: Swapping the GSR intake valves with the ITR intake valves ? (GZR4DR)
30% lighter
Not quite that much. Try 12% instead.
MurtazaDSM
Jan 19, 2012 02:31 PM
RMXmitch
15
Nov 29, 2007 02:55 PM
encognito
Feb 1, 2005 01:55 PM
Burglar
Dec 1, 2002 07:28 PM
TRuST
Dec 10, 2001 06:20 AM
