Coolant Leaking. Car overheating
Old Aug 28, 2007 | 12:51 PM
isaacEK's Avatar
Default Coolant Leaking. Car overheating
My car has been leaking coolant for awhile now. I have been just pouring more and more water into the radiator. Now it's getting to the point where everytime I drive I notice a BIG puddle wherever my car sits. I've replaced the radiator(did it about 4 weeks ago.) My car is slammed, so that may be the problem? Do I need a new radiator?
I jacked it up and looked where it was leaking and couldn't see much because of the plastic guard on the bottom of the bumper. It is leaking on the front part of the driver's side somewhere I know that. Can anyone help me out?
Old Aug 28, 2007 | 12:53 PM
PrinceAli132's Avatar
Default Re: Coolant Leaking. Car overheating (isaacDC)
Remove the plastic part and see if you can see anything. Check around the waterpump to see if it is leeking from there.
Ali
Old Aug 28, 2007 | 01:03 PM
EKris's Avatar
Default Re: Coolant Leaking. Car overheating (PrinceAli132)
check all ur lines. i remember that in my ek that there was a hole in the hose/line. and just replaced it. it was right next to my thermostat and connected to the back of the block.
Old Aug 28, 2007 | 01:05 PM
isaacEK's Avatar
where is the water pump located? that's where I thought it was coming from, but wasn't sure if it was on the front of the motor.
Old Aug 28, 2007 | 01:16 PM
Default Re: (isaacDC)
Water pump is located on the drivers side of the motor. It is a little to the right of the drivers side motor mount and a few inches down. You will not see it due to the fact that the timing belt covers (black plastic) covers it.
If it is leaking in the front of the motor, check the coolant lines and maybe headgasket.
Ali
cd5_2NR
May 13, 2013 06:30 PM
flipldls
May 9, 2010 02:14 PM
Honda_wannabe
Mar 9, 2010 03:40 AM
TylerLorenz
May 31, 2009 07:30 AM
tossnupweight
Dec 7, 2003 12:12 PM
