removal of radiator support?
Old Aug 28, 2007 | 12:19 PM
philosofy1's Avatar
Default removal of radiator support?
i was recently in a little accident. my accord took alittle beating. i need to replace some front end stuff, which i can pretty much do, but the one thing that seems to be giving me alittle trouble is the radiator support. i would i go about removing it?
http://www.thehondapartsstore....ch=no
it is item #4 on the list.
Old Aug 28, 2007 | 05:41 PM
TouringAccord's Avatar
H-T Order of Merit
Default Re: removal of radiator support? (philosofy1)
it's welded on. You need to drill out the welds or some other method of separating the welded parts. Then weld the new support back into place.
Old Aug 28, 2007 | 05:44 PM
arielb1's Avatar
I want to help, but your question is not clear.
Are you trying to remove and replace the radiator and you dont know how?
Are you trying to replace the front end the holds the radiator in place?
If the latter, dont forget to go to junk yards...they have these for cheap. Also, try hondaautomotiveparts.com.
Ariel
Old Aug 29, 2007 | 12:58 AM
philosofy1's Avatar
Default Re: removal of radiator support? (arielb1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielb1 &raquo;</TD></TR><TR><TD CLASS="quote">I want to help, but your question is not clear.
Ariel</TD></TR></TABLE>
i know how to replace a radiator, that's not the problem. i was in an accident, so my front end is damaged.
evolutiongsr
Mar 31, 2013 08:26 PM
philosofy1
Paint and Body
Aug 29, 2007 12:54 AM
cilvia
20
Apr 18, 2007 07:34 AM
BrokenRex
Oct 27, 2005 12:03 PM
B18CYAAA
Jul 14, 2003 03:22 PM
