ls/vtec not crackilakin
Old Aug 27, 2007 | 11:22 PM
be8teensee1's Avatar
Default ls/vtec not crackilakin
well it is cracking vtec but it seems weak and every time i hit it the check engine light comes on . oil level is fine , its wired correctly , the funny thing is when i go to check the code it has none because when i turn the car off it clears it. i even tried checking it with the car on just to see if it would work but no luck ....anyone else ever had this happen to them?
Old Aug 27, 2007 | 11:49 PM
Default Re: ls/vtec not crackilakin (be8teensee1)
Old Aug 28, 2007 | 12:26 AM
12345
Old Aug 28, 2007 | 01:25 AM
BoostFedDB8's Avatar
Seems like u are losing memory. Check to see if ur backup fuse under ur hood is still good.
Old Aug 28, 2007 | 10:20 AM
Default Re: ls/vtec not crackilakin (BoostFedDB8)
WILL DO . thanks
Old Aug 28, 2007 | 11:38 AM
backup fuse 7.5 is good
Old Aug 31, 2007 | 08:18 AM
champLSinteg's Avatar
make sure all the everything on the vtec solenoid is hooked up right and the wires all lead to the correct pin on the ecu. Sounds like the vtec oil pressure switch
mtg4gen
Apr 9, 2007 09:02 PM
veilsides2000
Nov 27, 2004 11:18 PM
clos0821
Sep 4, 2004 12:57 PM
civic-si-2000
Jun 14, 2003 01:00 PM
