fuel injectors?
Old Aug 27, 2007 | 09:49 PM
ben222's Avatar
Default fuel injectors?
I wana get new fuel injectors cause i dont think my car is getin enough fuel and i wana make some little changes before possibley turboing but i dont know what cc i need..y8 head with stage 1 cam with vtec..what cc do i need for that and what cc would i need if i went turbo
Old Aug 27, 2007 | 10:12 PM
blake_mp's Avatar
Default Re: fuel injectors? (ben222)
what HP range are you looking for? what setup are you running now? 450cc Dsm injectors are cheap and good for about 300. give or take. what tuning you running? get a FPR and up it a little.
Old Aug 27, 2007 | 10:19 PM
doood's Avatar
been there done that
Default Re: fuel injectors? (blake_mp)
injector size is based on projected hp levels. just throwing bigger injectors in there now is pointless and without tuning makes the engine run rich. stock injectors are fine for what you have now.
Old Aug 27, 2007 | 10:30 PM
ben222's Avatar
Default Re: fuel injectors? (doood)
would the 450cc make any difference from the stock injectors?..
Old Aug 27, 2007 | 10:31 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">just throwing bigger injectors in there now is pointless and without tuning makes the engine run rich. stock injectors are fine for what you have now.</TD></TR></TABLE>...
Old Aug 27, 2007 | 11:04 PM
CALC!_JUST_du_IT!'s Avatar
Fuel injector aren't designed to run at such low duty cycles. 450cc/min injectors will not flow accurately/predictably, and will make tuning almost impossible. Stock injectors are the appropriate size for just about any NA D-series. Only use the DSM's when you start boosting.
MyF20b_Prelude
May 30, 2015 08:43 PM
HondaKid936
Nov 13, 2008 07:16 AM
russianswty
27
Nov 14, 2006 06:30 PM
Thumper!
May 24, 2004 11:49 AM
sp0017
Mar 25, 2004 05:49 AM
