Starter Mounting Issues!!!!!
Old Aug 27, 2007 | 10:53 AM
slacks's Avatar
Default Starter Mounting Issues!!!!!
One one of the holes in my engine black where the starter is mounted.... it's stripped!!
I can only hold in one bolt for this! What should I do?
A friend of mine suggested "tapping?" or something similar.
Please explain any solution to this problem is you can. :/
Old Aug 27, 2007 | 11:32 AM
slacks's Avatar
Default Re: Starter Mounting Issues!!!!! (slacks)
bumped?
Old Aug 27, 2007 | 11:37 AM
95vxtealhatch's Avatar
Does your car start ok? If so then do nothing.
Old Aug 27, 2007 | 12:23 PM
slacks's Avatar
the car starts if the starter is mounted in, but there is an overwhelming fear that both bolts not locked onto the engine block could eventually cause the starter to break like the last one.
or do I not have to worry about that? (starter durability isn't something familiar to me)
Old Aug 27, 2007 | 12:27 PM
Luserkid's Avatar
I would tap it, ive seen starter housings break due to 1 bolt.
Old Aug 27, 2007 | 12:38 PM
slacks's Avatar
Default Re: Starter Mounting Issues!!!!! (Luserkid)
I've been told to tap it.
How would this be done though? The only information I can give you is that the Hex bolt is 10mm.
Any information would be of use
Old Aug 27, 2007 | 12:45 PM
Luserkid's Avatar
Which bolt is it, the short or long? If its long you have to drop the trans to gain access. If its the short you could probably just get the correct tap size (go to a machine shop and bring them a bolt saying you need a tap kit for this type of bolt) and go to work.
Old Aug 27, 2007 | 01:03 PM
slacks's Avatar
there is a long bolt for the lower mount?????? wtf?!?!?! i thought they were the same size!! (sorry, the car only had one bolt when it was purchased)
would you happen to know the size of it so i could try and find it?
Old Aug 27, 2007 | 01:12 PM
ek4_b16a's Avatar
ahahaha...so this whole entire time you thought you had a stripped bolt...!?!? sucks man...just ended up being a wrong length bolt? ahahhaa..hilarious...sorry...call up honda and try to get a size on that bolt...if not, just get one from the dealer...or just go to some parts store and see if they can find one for you....or the junk...ahahahah...sorry for laughing..i'd be if i figured that out myself...GL!!
Old Aug 27, 2007 | 01:23 PM
MonkeyBoy668's Avatar
Yep, if you call a dealership you can order the correct bolt for that particular car. Just give them the year & model, then explain which bolt you need.
If it's a swap (b16 engine + s21 transmission in a crx, etc.), just give them a year & model of a car the trans came with. They need to look it up on the parts list / diagram for the original car. Looking it up for your year/model won't do any good if your car didn't come from the factory with that transmission.
Though for all I know they're all the same size bolts... but always better to be safe than sorry...
Old Aug 27, 2007 | 02:23 PM
instrument's Avatar
just go to home depot and get a long bolt the same size as the bolt you have.
one of the bolts is like 3 inches long the other is like 4 maybe five?
but they are both the same size.
Mhollaek9
Honda CR-V & Element
Apr 27, 2024 06:46 PM
crxaddikt
Jun 12, 2012 10:48 PM
exxybihon
Aug 29, 2008 03:37 PM
Elite Hatch
Nov 24, 2002 10:06 PM
