b16 transmission
crap!!!! get a s1... the final drive is a 4.4
i ran one and its geared just right... i think the ys1 also has a 4.4 final drive but the actual gears are a little bigger then the s1's gears i dont actually know... all i know is that my s1 felt a little shorter geared then my freinds ys1
any cable trans will work, try to avoid an LS trans unless you are going turbo. you can run a hydro trans with a little bit of work, making a bracket so that your clutch cable will be doing the work of the slave cylinder that is supposed to be in its place.
ever'sneighborhood
20
Jul 26, 2011 11:51 AM
taggart_lumpy
Feb 11, 2007 06:11 PM
