200 WHP B-Series
Wanted to know what it took for some of you to achieve this mark. Post your spec/setup as I will be looking at building an engine in the next couple months. Is this number achieveable with mostly OEM internals?? Is a race header (no AC) necessary? The engine I have in mind is a JDM b18c (GSR) and was hoping to use ITR spec cams... Just looking at options/experiences so no flames please. Thanks in advance.
i think you might need more than that to reach you goal my setup
POORMANS ITR
GSR block .030" over
B16 head milled .020" and ported
ITR pistons
GSR crank
GSR rods
CROWER cams AEM cam gears
ALL the bolt ons except a TB and a really good header(ihad a cheap meagan)
tuned on hondata
189whp and 119tq
POORMANS ITR
ITR pistons
GSR crank
GSR rods
tuned on hondata
189whp and 119tq
On our old setup we had was a B18c1 block with CTR pistons,stock crank and rods.Headwork,cams,ported IM and Tbody were done by Gude Performance and we made 205 whp and 140 ft.lbs tqe. Tuned on CROME PRO by Chris Whitfield. Our best time with this setup was 12.50 @ 108 mph in our Eg. Pretty much all O.E. Built.
STOCK B18C5 Bottom End
B16 Head Non Ported - just portflow springs and retainers on stock b16 valves
LS Crank Pulley with A/C Belt, no P/S Belt
Blox B Cams
J's Racing Intake - Type R Throttle Body - Skunk2 Intake Manifold - Ported 98+ Spec JDM ITR 4-1 Header - NO CAT - 2.5" exhaust
194 WHP @ Pro Street Import on Crome
Blox B Cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PWRSPDEG »</TD></TR><TR><TD CLASS="quote">On our old setup we had was a B18c1 block with CTR pistons,stock crank and rods.Headwork,cams,ported IM and Tbody were done by Gude Performance and we made 205 whp and 140 ft.lbs tqe. Tuned on CROME PRO by Chris Whitfield. Our best time with this setup was 12.50 @ 108 mph in our Eg. Pretty much all O.E. Built. </TD></TR></TABLE>
Those are some good numbers especially with torque.
Yo man,
I think ITR cams and trying to reach 200whp is a bit tough. I'm sorry man! Your going to need more. Tom this will show you how tough it is:
https://honda-tech.com/zerothread?id=1263436
Maybe go FI. ITR cams are one of the best FI cams around!
i plan on building my motor soon, wonder if any of you guys can give some feedback on how my setup should be. This setup will be daily driven and road raced occasionally, and i want to make around the 200whp mark. I think this setup should well pass the 215whp mark.
B18c1
skunk 2 pro 2 cams
skunk 2 pro cam gears
skunk 2 pro valve springs
skunk 2 tit retainers
skunk 2 valves
hot tank hone block
rsmachines jdm itr pistons (std)
B18c1
skunk 2 pro 2 cams
skunk 2 valves
hot tank hone block
EK9 BEEZLER
Oct 17, 2005 04:08 PM
