fuel getting mixed with oil?
i checked the oil on my car this morning and it was at the full mark, i expected it to be a bit down after a kinda big beatin the night before. anyway the oil seemed really thin ,it hasnt mixed with water as it would go cream/whitish , the only thing i can think of is fuel mixing with it. any one ever seen this or had it on there motor?
setup is a completely stock b16a2. log mani,T3/t4 .63AR. running 10psi.
could be a stuck or dirty injector. does the oil smell like gas? you can check the injectors with a long screwdriver by puting it on the injector while the car is running and puting your ear on the handle. you want to hear if the injector is clickiing like it should.
io_burn
Jan 5, 2003 10:19 AM
