fuel getting mixed with oil?
Old Aug 26, 2007 | 05:19 AM
flangemastermike's Avatar
Default fuel getting mixed with oil?
i checked the oil on my car this morning and it was at the full mark, i expected it to be a bit down after a kinda big beatin the night before. anyway the oil seemed really thin ,it hasnt mixed with water as it would go cream/whitish , the only thing i can think of is fuel mixing with it. any one ever seen this or had it on there motor?
setup is a completely stock b16a2. log mani,T3/t4 .63AR. running 10psi.
Old Aug 26, 2007 | 05:57 AM
dbiker207's Avatar
Default Re: fuel getting mixed with oil? (flangemastermike)
could be a stuck or dirty injector. does the oil smell like gas? you can check the injectors with a long screwdriver by puting it on the injector while the car is running and puting your ear on the handle. you want to hear if the injector is clickiing like it should.
Old Aug 27, 2007 | 01:51 AM
oil doesnt smell off gas , just really thin oil. gonna go check the injectors , then change the oil and check back it again after driving.
Old Aug 27, 2007 | 06:18 AM
DeadVet's Avatar
Default Re: (flangemastermike)
What are you using for oil?
Old Aug 27, 2007 | 01:50 PM
Default Re: (1TurboHatch)
not sure if you get it in the US, use regular castrol 10w40 part synthetic.
zach53
Feb 28, 2012 03:05 PM
nitrofish420
Jan 6, 2007 09:26 AM
TomTomTuning
Honda S2000
32
Jul 5, 2006 06:16 AM
jeremy.
Nov 3, 2003 07:23 AM
io_burn
Jan 5, 2003 10:19 AM
