noise from supercharger
Old Aug 20, 2007 | 03:36 PM
drewb16a's Avatar
Default noise from supercharger
hey ht.im getting a weird noise coming from my jrsc,its like humming noise.its on my b16.i never got that noise before and the jrsc belt is not on,i dunno what it could be.do you have to put oil in a jrsc?
Old Aug 20, 2007 | 04:13 PM
spets's Avatar
if the belt is not on, then it is not the JRSC.
Old Aug 20, 2007 | 04:15 PM
Crx Jimmy's Avatar
Default Re: noise from supercharger (drewb16a)
its probably an idler pulley
Old Aug 20, 2007 | 04:21 PM
drewb16a's Avatar
Default Re: noise from supercharger (Crx Jimmy)
i hear the noise from the jrsc...where is the idler pulley located...i have idle problems since the noise started.it would idle at 2k rpm,it would go down when i rev high then it would idle at 1k.
Old Aug 20, 2007 | 04:34 PM
Crx Jimmy's Avatar
is the JRSC brand new or used?
Old Aug 20, 2007 | 04:35 PM
drewb16a's Avatar
its has about 9k miles
Old Aug 20, 2007 | 08:19 PM
drewb16a's Avatar
bump
Old Aug 20, 2007 | 08:22 PM
JaredKaragen's Avatar
a hum...
could it be from the IACV? they can be loud... but you say your hearing it when the car is running... sometimes you can hear the iacv hum when the ign is off... but throwing it out there.
Anyways, if the JRSC belt is off it aint spinnin.. maybe that hum is the sir making its way past the lobes/bypass valve?
Old Aug 27, 2007 | 02:00 PM
drewb16a's Avatar
Default Re: noise from supercharger (JaredKaragen)
it was my hose going into the jrsc
EF Boy1231
May 30, 2008 06:22 AM
typerhedlights
Apr 15, 2005 06:27 AM
typerhedlights
Apr 15, 2005 06:24 AM
TOFU.man
Mar 6, 2004 07:48 AM
OldSkool3
Jun 30, 2002 11:49 PM
