Please help with O2 sensor. CEL.
Old Aug 25, 2007 | 04:51 PM
HOWARDtheGREAT's Avatar
Default Please help with O2 sensor. CEL.
OK, Just bought my first civic. Its a 96 civic cx. I went to the auto parts store and had them plug it up and it came back throwing 2 codes. O2 sensor heater (sensor 1 and 2).
Will someone please tell me what to do and how to fix this. My car does have an aftermarket AEM intake on it. Ill take pics if you think that will help. Thanks.
Old Aug 25, 2007 | 05:00 PM
hondamark35's Avatar
Default Re: Please help with O2 sensor. CEL. (HOWARDtheGREAT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOWARDtheGREAT &raquo;</TD></TR><TR><TD CLASS="quote">I went to the auto parts store and had them plug it up... </TD></TR></TABLE>
plug what up?
you need a new o2 sensor. that'll fix it. your intake has nothing to do with this.
Old Aug 25, 2007 | 05:07 PM
Default Re: Please help with O2 sensor. CEL. (hondamark35)
Ok thanks. Is this something I can install on my own? If so how hard and what kinda stuff would I need to do it?
Old Aug 25, 2007 | 05:10 PM
cmasonrun's Avatar
Get an o2 sensor that is plug and play not that bosch crap that you have to wire yourself!!!
you need a jack, a ratchet, and a O2 sensor socket that is the same size drive as your ratchet.
Lift the car up....
unscrew the o2 sensor and unplug it, or Vice versa. and reinstall the new o2 sensor and plug it in,
disconnect the battery and your re connect it and your good to go!!!!!!!
Old Aug 25, 2007 | 05:13 PM
Default Re: Please help with O2 sensor. CEL. (cmasonrun)
Thanks man Ill see what I can do.
Old Aug 25, 2007 | 05:16 PM
Oh yeah one more thing, where is the O2 sensor located and what is a O2 sensor socket?
Old Aug 25, 2007 | 05:23 PM
cmasonrun's Avatar
the O2 sensor is located ON the exhaust pipe BEFORE the catalytic converter
and a O2 sensor socket is a socket that has a slit down the side so you can unscrew the sensor, the wire coming off the sensor gets in the way of a normal socket, you can get them at autozone, the same place yuo get the sensor at, just ask them.
It isn't hard, you can do it, GL
Old Aug 25, 2007 | 05:24 PM
elmo908's Avatar
you might want to disconnect the battery before you unplug the old one.
Old Aug 25, 2007 | 05:26 PM
cmasonrun's Avatar
Default Re: (elmo908)
yes, thank you...i think my post was out of order, lol
Old Aug 25, 2007 | 05:27 PM
Default Re: (cmasonrun)
Thanks a lot guys.
Old Aug 25, 2007 | 05:53 PM
19cIvIc94's Avatar
Default Re: (HOWARDtheGREAT)
And also if you don't have a socket or anything that will fit the o2 sensor, Autozone will rent you out the socket piece for like 10 or 15 bucks, and you get that money back including the tax once you return the tool.
'96typeR
15
May 17, 2008 11:13 AM
EJ8chu
Jan 20, 2007 12:53 PM
d_mina
Dec 2, 2004 09:43 PM
so simple
Nov 24, 2004 10:54 AM
99ls
May 21, 2003 09:17 PM
