wat grit to sand eoxy primer before laying bondo?
Old Aug 25, 2007 | 04:51 PM
msinsky14's Avatar
Default wat grit to sand eoxy primer before laying bondo?
as the title says, im blending welded quarter panels with the body, and I'm going to lay epoxy primer before bondo, and wet or dry?
thanks
Old Aug 25, 2007 | 05:49 PM
SneezinCD5's Avatar
Default Re: wat grit to sand eoxy primer before laying bondo? (msinsky14)
I usually use somewhere around 80+/- grit. It all really depends on what you are covering. Either way it will hide the scratches. It needs something to bite into.
I wouldn't recomend using Bondo, I use Evercoat products. Very good quality stuff.
Old Aug 25, 2007 | 07:39 PM
msinsky14's Avatar
Default Re: wat grit to sand eoxy primer before laying bondo? (SneezinCD5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 &raquo;</TD></TR><TR><TD CLASS="quote">I usually use somewhere around 80+/- grit. It all really depends on what you are covering. Either way it will hide the scratches. It needs something to bite into.
I wouldn't recomend using Bondo, I use Evercoat products. Very good quality stuff. </TD></TR></TABLE>
80 grit to suff the epoxy underneath the filler?
sorry, bondo to me is like kleenex, u say it, even if its not kleenex brand. i am using evercoat extreme, i kno that **** rocks!
Old Aug 27, 2007 | 02:26 PM
mztykal's Avatar
I don't sand epoxy.
I usually lay 2 coats of high build, sand that and then do my filler work so I know where all the high/low spots are...
Old Aug 28, 2007 | 05:52 PM
msinsky14's Avatar
Default Re: wat grit to sand eoxy primer before laying bondo? (mztykal)
so just a coat of eposy primer but not sand it, filler, then urethane primer?
Old Aug 29, 2007 | 01:19 AM
mztykal's Avatar
That's what I normally do. I shoot the epoxy over 80 grit sanding though.
Old Aug 29, 2007 | 11:50 AM
msinsky14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mztykal &raquo;</TD></TR><TR><TD CLASS="quote">That's what I normally do. I shoot the epoxy over 80 grit sanding though. </TD></TR></TABLE>
sand the metalwith 80 then lay epoxy? i dont see why I'd need to sand bare metal first
DC5_lov3r
Paint and Body
Jun 4, 2008 06:58 PM
95ejjj
Jan 30, 2006 05:01 PM
TRN
Jul 15, 2005 09:32 AM
130R
Aug 18, 2004 12:57 AM
Denny
Jul 12, 2003 09:09 PM
