having issues please give guidence or help
Old Aug 25, 2007 | 01:51 PM
Nite_2nr's Avatar
Default having issues please give guidence or help
Im getting serious power issues. I am currently running a b16a2, cp 9:1 pistons, eagle h beam rods, rc 550s, greddy 18g (running 15 psi and tappering down to 10), Greddy type rs blow off valve, crome p28 for tuning, gm 3 bar map, MSD coil, cap, rotor, wires. Well here the dyno graph from today and before when i didnt have my msd things on. The car is running at 12:1 afr and no more *under full boost*. I know im in need of a differnt mbc but just havent got one yet. here is the graph
I gained a lot of power at vtec change over with the new msd things but no more than 205 max horse power. From what ive been told i should be way higher than that. Please help ive tried so much on this car and none of it is working. Thank you.
Old Aug 25, 2007 | 02:48 PM
Nite_2nr's Avatar
Default Re: having issues please give guidence or help (Nite_2nr)
bump for help
Old Aug 25, 2007 | 06:09 PM
Nite_2nr's Avatar
come on guys im loosing my mind...
Old Aug 27, 2007 | 06:18 PM
Nite_2nr's Avatar
bump
Old Aug 27, 2007 | 06:50 PM
funk.regulator's Avatar
hows your cam timing?
Whats your exhaust system?
Old Aug 27, 2007 | 07:22 PM
Chris Tune's Avatar
wow... that graph looks like an electrocardiogram
Old Aug 29, 2007 | 07:11 PM
Nite_2nr's Avatar
Default Re: (Chris Tune)
cam timing is factory spec. factory cams. But as for exhaust i have 2.5 cat back but greddy o2 housing and downpipe (which are going to be taken car of ASAP)
Old Aug 30, 2007 | 02:00 PM
92NoTeC's Avatar
Default Re: (Nite_2nr)
Have you had the same ECU the whole time you've been turbo'd?
I still think it might be something in your dizzy, but an ECU swap would weed out that possibility.
Old Aug 31, 2007 | 05:30 PM
Nite_2nr's Avatar
Default Re: (92NoTeC)
yea ive had the same ecu since turbo. what in the dizzy would be bad? its got a new ignitor, new cap, new rotor, new coil....isnt that everything lol. As for ecu's i was using the ls/vtec b4 so i dunno we could try that. Im thinking about getting the msd 6al and me and nate are going to do my exhaust soon here so we can maybe try and tune it again u know?
h2b_sedan
Engine Management and Tuning
Sep 30, 2009 01:13 PM
Jagolas
Jul 2, 2004 12:27 PM
douglas_be
Feb 10, 2004 11:04 AM
NirVTEC
Dec 1, 2003 02:50 PM
