tail light problems
ok, to start i did a search but couldnt find anything to help me specifically. my running lights dont work. my brake lights all work just not the running lights. i replaced the fuses and the bulbs. any suggestions?
hey man i had the same problem...u have a ground somewhere thats not grounded check all the wires that lead to the main fuse box...other than that it will blow everytime you stick another fuse in it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8linek »</TD></TR><TR><TD CLASS="quote">alright im checking</TD></TR></TABLE>
don't listen to him.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hafaadaiteg »</TD></TR><TR><TD CLASS="quote">hey man i had the same problem...u have a ground somewhere thats not grounded check all the wires that lead to the main fuse box...other than that it will blow everytime you stick another fuse in it</TD></TR></TABLE>
what do mean he has a ground that is not grounded, how would you expect him to check, visually?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by str8linek »</TD></TR><TR><TD CLASS="quote">update. i just stuck a new fuse in the taillight location and as soon as i turned the lights on it blew that fuse. any ideas?</TD></TR></TABLE>
you have a wire shorting out, this is why your lights and fuses do not work.
unless you are lucky and can find or know where the problem is visually, you will need a test light or voltage meter to troubleshoot the wires. this is the only way.
good luck!
good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
good luck!</TD></TR></TABLE>
yah, youll just need to work your way from one end to the other. if you put new fuses in it (and make sure theyre the correct amp rating) and they keep blowing, then obviously you have too much voltage. just like philosofy said, you have short somewhere
FBP Si 2000
Dec 23, 2003 05:16 PM
wu tang
13
Jul 19, 2003 03:39 PM
