Half Del sol FAL Fan on Koyo Full Radiator (need help for my build)
Old Aug 24, 2007 | 11:59 AM
KrenzyRyan's Avatar
Default Half Del sol FAL Fan on Koyo Full Radiator (need help for my build)
Alright guys, workin on my build and I really want to use my FAL fan that I was running when I had the half radiator in, and here is my problem:
This is the old setup (sorry only pic)
Heres the problem:
Looks like the radiator hose clamp is going to get close the the fan shroud - anyone ever cut these?
Old Aug 24, 2007 | 12:16 PM
jayturboef's Avatar
Default Re: Half Del sol FAL Fan on Koyo Full Radiator (KrenzyRyan)
yea you can cut the shroud back i little but after you cut it make shure to yake a file and take the edge off because it will cut the hose...just dont go apeshit with the dremal tool... also if you have the room try to slide it over a half inch or so that way your not cutting on the very top of that fan blade just to give yourself some more room..good luck
Old Aug 24, 2007 | 03:06 PM
KrenzyRyan's Avatar
Default Re: Half Del sol FAL Fan on Koyo Full Radiator (jayturboef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayturboef &raquo;</TD></TR><TR><TD CLASS="quote">yea you can cut the shroud back i little but after you cut it make shure to yake a file and take the edge off because it will cut the hose...just dont go apeshit with the dremal tool... also if you have the room try to slide it over a half inch or so that way your not cutting on the very top of that fan blade just to give yourself some more room..good luck</TD></TR></TABLE>
Awesome thanks for the advice! From what it looks like, I may have to cut all the way through on the top part of the shroud, is that ok to?
Old Aug 28, 2007 | 05:17 AM
jayturboef's Avatar
yea should b
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
ID_ten_T
Nov 26, 2012 01:37 PM
asocallocal
Jun 9, 2005 10:22 AM
91DroppedHatch
Mar 3, 2005 02:56 PM
808State
Mar 11, 2003 12:56 AM
