white smoke after turbo kit
Old Aug 24, 2007 | 07:16 AM
bseries_beast's Avatar
Default white smoke after turbo kit
i have a hatch with a ls motor and i just put a turbo kit on about 2 months ago. Last night after i got in it a few times and when i parked white smoke was just pouring out the exhaust. But when i was drivin home normally there was no smoke at all. Its happened a few time before but it doesnt do it unless i get into it a lot. I also have a leak from the rear main seal but i doubt that would be why smoke is coming out the exhaust. I know im burnin oil too becuase its on the back of my rear bumper. Sometimes after i get into it but not often there will be a blue tint to the white smoke but its not a lot. But last night it was all white and just pouring out the exhaust. Could this be piston rings or maybe headgasket?
Old Aug 24, 2007 | 07:56 AM
sleepgsr's Avatar
Default Re: white smoke after turbo kit (bseries_beast)
Most likely your head gasket. Check if you are running low on coolant and check if your oil has some water in it.
Old Sep 4, 2007 | 12:06 PM
ebizzle361's Avatar
what kind of oil are you using? if its 5w20 its too thin and is seeping past your seals so try 10w30 because it is a little thicker and let me know if it still smokes
Old Sep 4, 2007 | 12:09 PM
Tchleung's Avatar
White = coolant
Blue = oil
Chances you are either blowing out the gasket/lifting the head when you're putting load on the motor
Old Sep 4, 2007 | 12:31 PM
SOHC_MShue's Avatar
Herman I told you that motor didn't look healthy when we first tuned it. Its been smoking ever since then. I know it was at least when you were racing those cars just a couple of days later. Like i said i would do a rebuild. Looked like all oil to me.
2kdrift
15
Feb 26, 2017 05:58 AM
oranginal
Apr 28, 2012 05:35 PM
Mikeedubb
Oct 14, 2011 03:57 AM
Joeski99Si
Aug 2, 2009 11:25 AM
MYKJDM
Jun 16, 2007 08:57 AM
