Help : V-AFC setting for a stock R motor?????
Old Jun 13, 2002 | 06:35 PM
DB8's Avatar
DB8
Default Help : V-AFC setting for a stock R motor?????
anyone done this on the Dyno? right now i am using a chipped P28 ECU(OBD1) with a untune V-AFC, anyone have any dyno proven V-AFC setting for the similar set-up? vtec point? where to set it rich or lead? etc????
Thanks in Advance
Old Jun 13, 2002 | 06:37 PM
98itR484's Avatar
Default Re: Help : V-AFC setting for a stock R motor????? (DB8)
i gonna tell you as a friend before people get on and start flamming you....every car is different...dont play around w/ that V-AFC..unless you're on a Dyno.
Old Jun 13, 2002 | 06:39 PM
DB8's Avatar
DB8
Default Re: Help : V-AFC setting for a stock R motor????? (98itR484)
i understand, but i am just looking for a basic setup, not trying to get some crazy power out of the V-AFC or anything, just want some suggestion, thanks for the heads-up anyway
Old Jun 13, 2002 | 06:52 PM
EleanoR's Avatar
Your basic setup should be to set the unit to 4 cylinders. Have the throttle position for 10% low and 50% high. Keep your stock VTEC setting and dont change anything until you are at the dyno.
mike
Old Jun 13, 2002 | 06:55 PM
uNF$@#!'s Avatar
Default Re: Help : V-AFC setting for a stock R motor????? (talkie25)
mike
actually i think the vafc downloads the stock configuration off the ECU when powering up the first time. this is what i've noticed.
Old Jun 13, 2002 | 07:05 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Help : V-AFC setting for a stock R motor????? (00-0187)
Must... resist... urge... to...
Hook it up, initialize it properly, and watch the pretty lights until you dyno your heap.
Old Jun 13, 2002 | 09:35 PM
ITR41's Avatar
New User
Default Re: Help : V-AFC setting for a stock R motor????? (Splat)
I know there is one site that gives basic settings for DSM's with specific turbo apps. to get a ballpark on a s-afc. why none for the vafc?
Old Jun 13, 2002 | 09:58 PM
shirubia's Avatar
mike
actually it doesn't it just stores the stock type r settings,
<---gsr owner who forgot to set the vafc once after initializing it
Old Jun 14, 2002 | 12:40 AM
comptechgsr's Avatar
ditto...
i've used it with a gsr ecu and an itr ecu...
it happens
rohec04
Jul 2, 2005 01:45 PM
gsrx
Nov 24, 2004 02:12 PM
sirminder
Dec 19, 2003 08:29 AM
The Poopsmith
May 26, 2003 09:16 AM
Quick_lude
May 16, 2002 09:51 PM
