VAFC Vtec correction?
Old May 24, 2003 | 01:44 PM
The Poopsmith's Avatar
Default VAFC Vtec correction?
I was messing w/ my VAFC and noticed the Hi>>>Lo, LO<<<Hi settings. I know this is supposed to make up for the difference in VTEC engaugement from the factory settings to the VAFC setting, but what number to you put in there?
Here is my example,
GSR- stock engagement 4400
VAFC engagement 5200
What number would I have to put in there? I know it has to be an equation of some sort to figure this out.
Old May 25, 2003 | 07:34 AM
Default Re: VAFC Vtec correction? (DeeSeeToo)
up, there arnt any VAFC masters in here?
Old May 25, 2003 | 02:31 PM
AzG35's Avatar
No equation, only dyno tuning will determine what that number "should" be.
Old May 25, 2003 | 04:21 PM
Evilteg's Avatar
Default Re: VAFC Vtec correction? (AzSi22)
DO NOT set it yourself tuff guy
Old May 26, 2003 | 06:58 AM
Default Re: VAFC Vtec correction? (Evilteg)
o...enlightenment...
Old May 26, 2003 | 08:18 AM
patdemps's Avatar
keep it stock until you get the car dynoed. Upon getting the car tuned (good tuner helps) they will set your vtec engagement at the best spot possible (once again needs to be a good tuner).
don't play with it yourself. your just going to mess up your ride.
Old May 26, 2003 | 09:16 AM
tilt's Avatar
Default Re: VAFC Vtec correction? (patdemps)
With more aggressive cams, the crossover usually gets bumped up. The crossover should be a relatively smooth transition. If you dip in power you are too low and if you pull hard suddenly you are prob set too high. And yes, you should eventually get the car tuned.
xelloss
Engine Management and Tuning
Oct 28, 2008 09:35 AM
B18C1 Civic EG
Aug 17, 2004 01:18 AM
tegon-gsr
Jul 10, 2003 08:14 PM
hondafrk
Feb 23, 2002 07:08 PM
