just changed my brakes and makes noise?!?!?!?!?!whats wrong????
Old Aug 23, 2007 | 09:18 PM
1jdmek's Avatar
Default just changed my brakes and makes noise?!?!?!?!?!whats wrong????
i just changed my front brake pads..and for some reason it feels that something is rubbing on eachother...i hear it when i gas it but i hear it even more when i brake what could it be?.
Old Aug 23, 2007 | 09:34 PM
Dilly's Avatar
Default Re: just changed my brakes and makes noise?!?!?!?!?!whats wrong???? (1jdmek)
you changed your pads and such right? if so, did you push your caliper piston back all the way?
Old Aug 23, 2007 | 10:04 PM
1jdmek's Avatar
Default Re: just changed my brakes and makes noise?!?!?!?!?!whats wrong???? (diLLy)
yeah just the pads...im pretty sure i did...but say i didnt even after i put the tires back on.. wouldnt the calliper slip out or something or wont it not brake?
Old Aug 24, 2007 | 06:29 AM
Contender25
Guest
Posts: n/a
Sometimes when your messing with things down there like changing shock/struts or pads/calipers or whatever, people manage to bump the brake dust shield. Try taking your wheel off and making sure it is straight and not rubbing/bent out of order too badly.
Old Aug 24, 2007 | 06:37 AM
speedooo's Avatar
Default Re: (Contender25)
i found out the hard way 1am in the dark that when you install brake pads backwards they grind...sounds dumb but check it
Old Aug 24, 2007 | 09:13 AM
daluv's Avatar
Default Re: (speedooo)
Lol!!!^^^^ My money's on the dustshield. Been there a million times!
ef8cybercrx
Nov 17, 2007 10:40 PM
92ehatch
Mar 23, 2006 07:06 PM
mikeds122
Sep 25, 2004 12:55 PM
AMG
13
Aug 18, 2004 09:03 AM
Ninja Mike
May 27, 2004 07:20 PM
