d16 - b16 engine harness question
Old Aug 23, 2007 | 06:42 PM
Dyce's Avatar
Default d16 - b16 engine harness question
i am working on a auto-5sp conversion along with a d16y8-b16a2 swap in my 00 ex bc i feel a auto-5spd swap alone isnt worth it on a D. so far my swap is complete, but my car wont start. it turns over and has spark. but a kid that came to check it out said that i am not getting power to my injectors. he also said its bc i reused my auto d16 engine harness since i couldnt find a B.
is the harness the reason y my car wont start or is it sumthin else? pls reply ppl, i havent had a car for 5 weeks now
Old Aug 23, 2007 | 07:05 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: d16 - b16 engine harness question (Dyce)
what year b16a is it? Obd1 or 2? The injectors for OBD1 and OBD2 are different.
Your wiring harness from your D16 will work just fine. The D16Y8 harness is the same as an Si pretty much. It has knock, and vtec.
b16a3delsol's Avatar
could be but probably not the problem. unless you botched the wiring job. any cels?
Old Aug 23, 2007 | 07:26 PM
B serious's Avatar
Default Re: d16 - b16 engine harness question (b16a3delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a3delsol &raquo;</TD></TR><TR><TD CLASS="quote">could be but probably not the problem. unless you botched the wiring job. any cels?</TD></TR></TABLE>
wiring job? it all plugs in.
Dyce's Avatar
the motor is a b16a2= 00 si motor, obd2
the injectors im using came out of my obd2 single cam.
i read up that the auto and 5spd sohc engine harnesses are different but idk exactly what.
how do you botch the wires?
i use to have cels but today i noticed that my CEL wasnt on but would turn on after trying to start the car
Old Aug 23, 2007 | 08:43 PM
Dyce's Avatar
ttt
Old Aug 23, 2007 | 08:44 PM
B serious's Avatar
Default Re: (Dyce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyce &raquo;</TD></TR><TR><TD CLASS="quote">the motor is a b16a2= 00 si motor, obd2
i use to have cels but today i noticed that my CEL wasnt on but would turn on after trying to start the car</TD></TR></TABLE>
well....you need B series injectors, brozef.
Old Aug 23, 2007 | 09:17 PM
Dyce's Avatar
i heard the sohc injectors will allow the car to run but have minor problems. and the wrong injectors shouldnt cause the injector plugs themselves not to get any power
Gumbygrom
May 13, 2018 10:28 PM
B_Swapped93
Dec 16, 2013 11:48 AM
ballerchild
12
Apr 3, 2007 12:41 PM
[Ennis_D]
Nov 30, 2006 12:07 PM
SC61HB
Jan 27, 2003 01:56 PM
