what eles is needed??
ok i got crome pro...inovative wideband..ssi-4 and the moastes ostrige...what eles is needed to datalog?or do i still need the 4 wires to my ecu as well?...with this stuff i have will i be able to see what cell im at on the map when im driving?
whats ssi-4? you'll need to wire an input to the ecu for the wideband. just disable o2 sensor on crome and tap the wire for the wideband ( PIN D14 white wire ) you will need a hondalog or similar to plug into the ecu. if u have it all set up u will be able to datalog and map trace! hit me up if u need help setting it all up.
Gant
May 18, 2005 08:47 PM
