what eles is needed??
Old Aug 23, 2007 | 03:32 PM
turbo boost's Avatar
Default what eles is needed??
ok i got crome pro...inovative wideband..ssi-4 and the moastes ostrige...what eles is needed to datalog?or do i still need the 4 wires to my ecu as well?...with this stuff i have will i be able to see what cell im at on the map when im driving?
Old Aug 23, 2007 | 05:23 PM
Default Re: what eles is needed?? (turbo EF)
Old Aug 23, 2007 | 05:31 PM
carcala's Avatar
whats ssi-4? you'll need to wire an input to the ecu for the wideband. just disable o2 sensor on crome and tap the wire for the wideband ( PIN D14 white wire ) you will need a hondalog or similar to plug into the ecu. if u have it all set up u will be able to datalog and map trace! hit me up if u need help setting it all up.
Old Aug 24, 2007 | 08:48 AM
Default Re: what eles is needed?? (carcala)
whats ur msn..ill add u
thevtecnician
Oct 5, 2009 07:22 AM
Gant
May 18, 2005 08:47 PM
midnightsilence
Oct 14, 2004 05:02 AM
This One
Feb 2, 2003 04:20 AM
slwazgsr
Sep 30, 2002 02:48 PM
