Can I reuse my header gasket?
Old Jun 13, 2002 | 04:26 PM
vteg's Avatar
New User
Default Can I reuse my header gasket?
My car has the original header with 55k miles. Should I buy new gaskets, or reuse my current ones when changing the header?
Old Jun 13, 2002 | 04:37 PM
Malice's Avatar
New User
Default Re: Can I reuse my header gasket? (vteg)
i just reused mine when i swapped headers. no problems
Old Jun 13, 2002 | 04:44 PM
Mr. Softee's Avatar
Default Re: Can I reuse my header gasket? (MaliceGSR)
ive reused mine like 10 times
Old Jun 13, 2002 | 04:49 PM
smeister's Avatar
Reused mine twice and my car has 101K miles.
Old Jun 13, 2002 | 05:00 PM
vteg's Avatar
New User
Default Re: Can I reuse my header gasket? (smeister)
Thanks for the info.
Old Jun 13, 2002 | 05:02 PM
Regular Series's Avatar
I've reused a valve cover gasket with no problems...
Old Jun 13, 2002 | 05:21 PM
frogsr's Avatar
Default Re: Can I reuse my header gasket? (risingson77)
sacrilege!
Old Jun 13, 2002 | 05:35 PM
Mase's Avatar
**** i do that all the time when i mess with the cam gear settings...i put the silicon sealant, and its stuck to the head, so i just carefully put the valve cover on.....no leaks....one day ill get another though..
Old Jun 13, 2002 | 08:12 PM
neo1z's Avatar
Default Re: Can I reuse my header gasket? (CDooMe2)
<---------- also reused gasket
Old Jun 13, 2002 | 08:15 PM
vteg's Avatar
New User
*bowing head*
I thought I was different, since I reused my valve cover gasket a few times.
Old Jun 14, 2002 | 11:22 AM
98DC2's Avatar
nice teg
Old Jun 14, 2002 | 01:06 PM
Malice's Avatar
New User
Default Re: Can I reuse my header gasket? (98lagen)
thank you
Old Jun 14, 2002 | 04:21 PM
erniecars's Avatar
i would not recommend reusing an *** gasket tho
Old Jun 14, 2002 | 05:04 PM
GreenD's Avatar
Default Re: Can I reuse my header gasket? (erniecars)
ive reused my header gasket 4 times & the valve cover gaskets, gromets & spark plug seals like 5-6 times. no leaks....yet.
Old Jun 14, 2002 | 05:58 PM
vteg's Avatar
New User
Default Re: Can I reuse my header gasket? (GreenDestiny)
I went to pick up my header, and the supplier gave the shop the wrong one
Now I have to find something constructive to do tomorrow.
Old Jul 18, 2003 | 12:44 PM
IntEGNYC's Avatar
Out of curiosity, how much does a header gasket go for?
Old Jul 18, 2003 | 01:18 PM
Aaron M's Avatar
Default Re: Can I reuse my header gasket? (IntEGNYC)
iv reused header gasket with no probs
and iv used my valve cover gasket about 10 times. no probs
Old Jul 18, 2003 | 01:22 PM
.RJ's Avatar
.RJ
Default Re: Can I reuse my header gasket? (SilverB18C1)
We pulled the header off a friend's LS with about 140K miles on it to put a new one on, and the gasket didnt seal properly.
So for $11 or so, its easy to just replace it when the header is off.
Old Jul 24, 2003 | 01:02 AM
vteg's Avatar
New User
Default Re: Can I reuse my header gasket? (.RJ)
Back from the dead,
My gasket is still working. The header has been off half a dozen times at least.
Old Jul 24, 2003 | 01:50 AM
IntEGNYC's Avatar
youre such a resurrector
for 10 bucks, you cant go wrong replacing the gaskets.
Old Jul 24, 2003 | 05:14 AM
Rory Breaker's Avatar
Ive reused the header gasket countless times, valve cover gasket a bunch, donut gasket, etc.
As long as they are in good shape when you take them off, there is no reason to replace them.
mimi75
Jan 31, 2016 10:18 AM
miksew
13
Oct 20, 2006 05:48 PM
-Championship-
Jun 29, 2006 10:59 PM
type Gendy
10
Sep 6, 2003 10:44 AM
Loveless
Apr 19, 2003 03:28 PM
