95 accord screeching noise from wheel
Old Aug 23, 2007 | 07:50 AM
boggey's Avatar
Default 95 accord screeching noise from wheel
there is a screeching noise coming from the passengers front wheel. The screeching starts when I turn right or sometimes its triggered when I hit a bump at faster speeds. When I come to a stop it goes away and doesnt start again until I speed up and turn right or hit a bump. I can also make it go away if I do a sharp left turn. It sounds almost like metal on metal. I checked and the brake pads are still good, as I replaced them last year. However the rotors are in pretty bad shape but i dont understand how a bad rotor could cause something like this, is that possible? Im planning on replacing the rotors anyways, I already have purchased new ones. Is it possible that its the rotors or could it be something like the wheel bearings?
Old Aug 23, 2007 | 08:10 AM
The-Kid's Avatar
Default Re: 95 accord screeching noise from wheel (boggey)
Hmmm... A screeching from the wheel area is an indicator you need to replace your brake pads. Check if the metal indicator tab is touching the rotor. You can hear metal to metal. Screeching in other words.
Have you ever checked you CV boots lately? See if there's any holes in the boots. The grease may either got thrown out and now you're experiencing the metal to metal.
Old Aug 23, 2007 | 10:17 AM
boggey's Avatar
Default Re: 95 accord screeching noise from wheel (The-Kid)
The brake pads are still good, over 50% left. I didnt consider the CV boot, I'll check that out next.
Dm914
Dec 11, 2015 02:12 PM
fisherboy1118
Jan 3, 2011 04:13 PM
BlueRocket
Jul 29, 2004 09:27 PM
sl0wED
May 15, 2004 08:42 PM
Charlie Moua
Jun 30, 2003 02:44 PM
