not sure if hondata will work?
will hondata work with a 2001 ls ecu?? i know i have to covert it to odb I with the harness, but I'm just not clear if it will work for my car.
thanks
savannakhet
thanks
savannakhet
AEM EMS might be a better solution if your odbII like me..... in the end its cheaper because you don't need to convert to odbI..... you just buy it and plug it in, thats it.. couldn't be simpler. Of course theres the tuning, but if you find a competent tuner he should be able to work with any standalone. Just my opinion
thanks for the reply. However, on the hondata site, they mention that 00-01 are not re-programmable. Can you guys clearify what exactly that means? I'm assuming that i would have to switch out my ECU.
thanks
savannakhet
thanks
savannakhet
youre better off gettin a p28 or obd1 compatible ecu. youll need the harness too. too bad man.. friend of mine from daly city was sellin a hondata, p28, and the harness for $750
AzN_Flava
Engine Management and Tuning
Sep 15, 2017 10:33 PM
crazyitr
Sep 30, 2006 12:39 PM
