Hondata Some Questions
Old Aug 24, 2004 | 07:51 PM
TurboTeG4's Avatar
Default Hondata Some Questions
First off im confused cause I dont understand why hondata does not update the instructions on the eumulator installation. It shows in the picture what looks like a old version of everything and documents the instructions on this particular version. They obviously have enough money to update it.
So my understanding is I will hook the romulator up with a adapter to my usb slot, cause I got the datalogging in my serial port. Will it automatically recognize the emulator, and what is the procedure to hook up the emulator, what is powering the emulator? My common sense tells me how to do it but I just need confirmation. Also if I burn me a stock base map for a gsr on a p28 will everything work fine exept for the butterflys?
Last but not least, will the Aem Uego Gauge be able to work with the hondata using the voltage splitter that was discussed in archived forums.
Old Aug 25, 2004 | 09:46 PM
AutoWerks's Avatar
Default Re: Hondata Some Questions (TurboTeG4)
the emulator is powered by the ecu. when you plug it into the ecu socket. You have to setup the rom editor in settings under datalog I think the com ports and aand emulator ver.
see http://hondata.com/pocketprogrammer.html
yes it will run fine with the p28 with no problems.
and yes the aem uego will work fine on hondata.
Old Oct 22, 2004 | 12:24 AM
TurboTeG4's Avatar
Default Re: Hondata Some Questions (AutoWerks)
How come when I burned and ran a stock p72 program on my p28 ecu on my 94 gsr, when I press the gas from idle theres a slight hesitation that I can feel?
Old Oct 23, 2004 | 10:17 AM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">How come when I burned and ran a stock p72 program on my p28 ecu on my 94 gsr, when I press the gas from idle theres a slight hesitation that I can feel?</TD></TR></TABLE>
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
aziz93
Aug 16, 2004 08:29 AM
JunIntegra
Apr 8, 2004 06:44 PM
KRiS1
13
Oct 3, 2003 01:10 PM
evo75
Jun 17, 2002 04:46 AM
