How many quarts of motor oil for B16A 2nd gen
Old Aug 22, 2007 | 06:31 PM
crazyguy's Avatar
Default How many quarts of motor oil for B16A 2nd gen
How many quarts of motor oil for B16A 2nd gen? drain and refill? i poured in 4 quarts, is it enough?
thanks
Old Aug 22, 2007 | 06:50 PM
drtysohc's Avatar
check it?
Old Aug 22, 2007 | 06:52 PM
97Ej6mike's Avatar
4 quarts is fine, but some specific book recomendations call for like 3.50 or 3.75 quarts.
crazyguy's Avatar
Default Re: (drtysohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drtysohc &raquo;</TD></TR><TR><TD CLASS="quote">check it?</TD></TR></TABLE>
i cant really tell from the oil dip stick cause i am not sure if thats original one that comes with the engine or
Old Aug 22, 2007 | 06:57 PM
97Ej6mike's Avatar
Default Re: (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">
i cant really tell from the oil dip stick cause i am not sure if thats original one that comes with the engine or </TD></TR></TABLE>
Is there any oil line/residue marked on your dipstick when you remove it? Remember new oil is yellow and can sometimes be hard to distinguish on the dipstick if you dont look at it closely.
Old Aug 22, 2007 | 08:16 PM
Tonymoto's Avatar
Default Re: (97Ej6mike)
whenits between the 2 dots
Old Aug 22, 2007 | 08:19 PM
Johnny Ricer's Avatar
Default Re: (Tonymoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tonymoto &raquo;</TD></TR><TR><TD CLASS="quote">whenits between the 2 dots</TD></TR></TABLE>
No the highest dot is reccomended height read your manual...
Old Aug 22, 2007 | 08:23 PM
ek guey's Avatar
Default Re: (soundpsych)
remember wen you do the oil change pour the oil in and turn your car on, let idle for half a minute, check dipstick again then adjust and try to fill it but dont overdue it cause that causes problems too
Old Aug 22, 2007 | 08:53 PM
VTAC-KAT's Avatar
Default Re: How many quarts of motor oil for B16A 2nd gen (crazyguy)
three and a 1/2 quarts is full. four doesn't hurt but the oil pan is 3.5 quarts
Old Aug 22, 2007 | 08:55 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundpsych &raquo;</TD></TR><TR><TD CLASS="quote">
No the highest dot is reccomended height read your manual...</TD></TR></TABLE>
True, but the second dot is "1 qt low" - so it's not like you're really lacking in oil or anything.
In the upper 75% of the range of the two dots to the top dot is fine.
Old Aug 22, 2007 | 10:04 PM
ejprimo's Avatar
Default Re: (Syndacate)
i always put 4.2 quarts into my b16a.
Old Aug 22, 2007 | 10:25 PM
Lscivic1999's Avatar
Default Re: (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">i always put 4.2 quarts into my b16a.</TD></TR></TABLE>
Old Aug 22, 2007 | 10:38 PM
wiZCo's Avatar
Stouts 'n' Scotch
It's usually around 4 1/4 for me as well.
Old Aug 22, 2007 | 10:47 PM
devney's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
It's usually around 4 1/4 for me as well.</TD></TR></TABLE>
same here.
Old Aug 23, 2007 | 12:00 AM
Mfoehrkolb's Avatar
4.25qrts
ender214
Feb 24, 2008 02:32 AM
invisible
21
Dec 27, 2006 08:27 AM
Civicse
24
Sep 12, 2005 08:46 AM
h2392si
16
Aug 25, 2005 07:18 AM
neilff
Jul 29, 2003 07:20 AM
