cooling fan
Old Aug 22, 2007 | 06:29 PM
aziaticvang's Avatar
Default cooling fan
for honda civic 93 dx, my fan never comes on when the engine is hot and the fan is still in working condition also!! so what is the deal?? the thermostat and coolant has been replaced also!
Old Aug 22, 2007 | 06:32 PM
95ProjectEJ1's Avatar
Default Re: cooling fan (aziaticvang)
Get yourself a paper clip and disconnect the connector attached to the thermoswitch located on the thermostat housing. Put each end of the paperclip into the female portion of the connector. If the fan activates, you have a bad thermoswitch. If the fan doesnt activate and you dont hear a click coming from your engine bay fuse box then you have a bad relay. Go test it and tell me what you find
Old Aug 22, 2007 | 06:39 PM
Default Re: cooling fan (95ProjectEJ1)
well i tested the part where the relay is plugged into with a wire and the fan turns on. if we were to stand to the side of the car by the fender, ill tell you exactly which slot i plugged it in! the bottom left slot and the upper right slot, that be the only way it turn on! i doubt that it would be my thermostat becuase i changed it already. but what are the female slots!?
Old Aug 22, 2007 | 06:44 PM
The brass colored parts is your thermoswitch. If you were to unplug that, the gray connector would have the "female" slots to plug the paperclip in.
Old Aug 22, 2007 | 06:45 PM
sinister357's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziaticvang &raquo;</TD></TR><TR><TD CLASS="quote">for honda civic 93 dx, my fan never comes on when the engine is hot and the fan is still in working condition also!! so what is the deal?? the thermostat and coolant has been replaced also!</TD></TR></TABLE>
i don't believe i've ever seen my gs-r's fan turned on either but it never overheat.
Old Aug 22, 2007 | 06:46 PM
WoW! That pic is larger than life itself. I need to get a handle on this resizing **** on photobucket.
Old Aug 22, 2007 | 06:55 PM
thanks, ill try it tomorrow and ill let you know cuz its pretty late here right now lol!
eqalias
Oct 11, 2013 03:19 AM
Ldo
Dec 8, 2008 11:43 AM
lilo_goki
Dec 3, 2007 02:47 PM
immalooser
Apr 8, 2007 01:00 PM
Paluce
Mar 20, 2007 09:33 AM
