5 lug conversion on crx
Old Jun 13, 2002 | 02:06 PM
Black R's Avatar
25 Year Member
Default 5 lug conversion on crx
I posted a topic a long time ago and there was a guy with a crx who had done the complete conversion.
He said it all swapped over and bolted up for the most part.
But now I can't find that thread through a search. WTF?
Anyone save the link maybe?
.....And before you start asking why, the brakes are why for autox and track! And the ability to run 5 lug wheels.
Old Jun 13, 2002 | 03:10 PM
JDMBOLONI's Avatar
Default Re: 5 lug conversion on crx (Black R)
i put 5 lug on my friends white 90 crx and all you need is the outer tie rod ends off an 94+ integra. i have pics i could post too but i dont know how to host them. if you have any questions about it let me know by e-mailing me at jdmhondaparts@hotmail.com
Old Jun 13, 2002 | 03:16 PM
RyanR's Avatar
Default Re: 5 lug conversion on crx (JDMBOLONI)
The tie rod ends on a 94+ integra are the same as the EF. I have Type R tie rods on my CRX and they bolt up fine to the EF knuckles. I compared them side by side and they were the same length too.
Old Jun 13, 2002 | 03:20 PM
JDMBOLONI's Avatar
Default Re: 5 lug conversion on crx (RyanR)
ok maybe you don't need 94+ integra ones, but he replace them........
Old Jun 13, 2002 | 04:21 PM
SuperTwinz's Avatar
http://universe.svwh.net/car_stuff/da_5lug/
Old Jun 13, 2002 | 04:43 PM
SuperTwinz's Avatar
http://battlecat.8m.com/ITR%205%20lug%20on%20DA.htm
Old Jun 13, 2002 | 06:32 PM
88 CRX SiR's Avatar
Default Re: 5 lug conversion on crx (SuperTwinz)
SuperTwinz - Thanks for the pics & links! Do you know if there is a how-to page for the conversion on a CRX? I'm not too sure how different they are compared to DA's.
Old Jun 13, 2002 | 08:35 PM
Black R's Avatar
25 Year Member
.....you guys swapped suspension components and brakes as well?
List of what to use off the itr perchance?
Old Jun 14, 2002 | 12:42 AM
Radex's Avatar
The main reason you do 5lug are the brakes I feel. I would also very much like to know the details for this black crx swap. It is obvious you need EX knuckles (or ITR knuckles?) for front. I've heared that trailing arms will do for rear but I guess we have different upper control arms in 4G. Lower control arms are 100% the same. What about sway bar?
Old Jul 9, 2002 | 05:26 AM
Charlie Moua's Avatar
Default Re: 5 lug conversion on crx (88 CRX SiR)
that's what i wanna know. how much different is the DA front to the EF si front
Old Jan 10, 2003 | 08:33 AM
E-AT_me's Avatar
how many times do i have to tell people stock brakes are fine for autocross? oh well. no one will ever listen to me, and hey, what the hell do i know..
Old Jan 10, 2003 | 08:51 AM
Black R's Avatar
25 Year Member
Default Re: 5 lug conversion on crx (Rexman)
Well, I have a FREE 5 lug conversion and set of rims I can use. That way, I can share rubber with my itr too... So that's why! I just need to find out what I need from the donor itr to swap over.
Old Jan 10, 2003 | 09:09 AM
d15dood's Avatar
damn, anyone got pics of a crx with 5 lug? sounds sweet.
Old Jan 10, 2003 | 10:58 AM
Black R's Avatar
25 Year Member
Default Re: 5 lug conversion on crx (battlecat187)
I had seen a pic of a white rex with 5-lug on here a LONG time ago in the archives... couldn't find it recently, but is must be out there...
Anyway, my questions right now are:
1. Anything different about the 5 lug to DA conversion from the 5 lug to EF conversion?
2. What about the itr master cylinder, proportioning valve, and an aftermarket brake bias controller? Necessary, or just neato to have? Anything else we're leaving out?
Old Jan 10, 2003 | 11:38 AM
Black R's Avatar
25 Year Member
.....oh yeah, what about the e-brake cable?
And anything else I forgot?
Old Jan 10, 2003 | 02:53 PM
CRX-RX's Avatar
1. Yes, the DA and Type-R knuckles are different geometry. They are approx.1/2" taller than the EF knuckles. Try it out, you'll see.
2. You can use an EX master cylinder and that will get you to 15/16" and bolt up. You'll really have to hack the car up to get a type R booster and cylinder on there, and you will have to redo the brake lines to install the cylinder by itself. You can use the prop valve, though I've heard the Del Sol is a better option for the ditributiuon because of the weight differences. You will also need to install the rear disc brakes the proper way by removing the hub/spindle assembly from the trailing arm and maintaining your stock trailing arm. You will need to get a set of 90-1 CRX Si E-brake cables. You don't need new tie rod ends, but they will have to be adjusted after swapping because toe will be off by about an 1 1/2".
Personally, I don't recommend the front's at all because the geometry sucks in any real racing circumstance. Perhaps if you got a set of SiR knuckles and used the hubs out of the Type-R, but I'm not too sure that that would work because the Type R's have a larger wheel bearing.
Old Jan 10, 2003 | 03:00 PM
bryant's Avatar
Its Marty's Friends car:
Old Jan 17, 2003 | 04:47 AM
Default Re: 5 lug conversion on crx (Bryant)
due i was planning on doing this swap... I know that JeffNA was also gonna do this and put on some RSX rims on....
ttt ---hoping to get more info on the swap
Old Jan 17, 2003 | 04:53 AM
Superhatch's Avatar
Default Re: 5 lug conversion on crx (Charlie Moua)
Ooooooo...That looks alot nicer than I thought it would.
-Jake
Old Mar 22, 2003 | 05:59 PM
Black R's Avatar
25 Year Member
Default Re: 5 lug conversion on crx (CRX-RX)
Thank you for your reply CRX-RX!
I have the complete salvage itr at my disposal, so I'm going to try and bolt up everything I can pull off the itr... Then I guess I'll find out the hard way...
I have a camber kit for the front because I've heard the biggest problem is the camber being positive after a swap like this.....
Anyone got new info?
Thanks.
Old Mar 22, 2003 | 07:26 PM
QWKPHKR's Avatar
What camber kit did you get for your rex?
Old Mar 22, 2003 | 08:03 PM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
would it work on a 89 hatch?
bolt right up or will it be similar to the crx?
Old Mar 22, 2003 | 08:47 PM
QWKPHKR's Avatar
Default Re: 5 lug conversion on crx (MR.RED'89)
would be the same as a CRX
JDM_Frijoles
Aug 28, 2009 03:52 PM
SupraRXZ
Apr 24, 2006 04:53 AM
risiah05
Feb 29, 2004 04:36 PM
blacksoul
Sep 15, 2002 06:13 PM
Turbo Lude SH
Aug 11, 2002 06:55 PM
