1995 Prelude Climate Controls
Old Aug 22, 2007 | 09:53 AM
11995lude's Avatar
Default 1995 Prelude Climate Controls
I have a 1995 SI, Not digital HVAC control. The fan and temperature controls both work. When I select the air for defrost, floor heat or bi-level buttons, they each light up no change in air flow occurs. Air is only blowing from the dash.
What do I need to check???
Old Aug 22, 2007 | 11:12 AM
mgags7's Avatar
the motors that control those vents are out.
Checking them is going to suck, check into a helms service manual for a procedure.
Old Aug 22, 2007 | 12:49 PM
charles1's Avatar
Default Re: 1995 Prelude Climate Controls (11995lude)
i had the same problem with my 92 prelude......
i took my circuit board for the air controls and all out and found that the sauder connections one it for where the plug went were actually cracked and were not making connections. i would pull that out and try to re sauder it or however you spell it.
Old Aug 22, 2007 | 01:03 PM
mgags7's Avatar
solder
never heard of that before, but it makes perfect sense
Old Aug 22, 2007 | 01:10 PM
smackdown's Avatar
Default Re: 1995 Prelude Climate Controls (charles1)
sauder makes furnitures too
Old Aug 22, 2007 | 02:12 PM
11995lude's Avatar
Default Re: (mgags7)
Where do I find the circuit board you are referring to?
Thanks!
Old Aug 22, 2007 | 02:15 PM
nonvteclude's Avatar
Default Re: (11995lude)
when you take the climate control out, inside that whole unit is the circuit board
Old Aug 22, 2007 | 03:20 PM
TheWalrus's Avatar
theres a writeup somewhere...search climate or HVAC
i tried doing this last week, my dad is an electrical engineer and he helped...it didnt work
moz92
Jan 4, 2010 08:41 PM
D16Z6_turbo
Oct 5, 2007 11:05 PM
user 528629372
Oct 18, 2005 08:07 AM
RFX
Dec 9, 2002 07:55 PM
