compression
Old Aug 22, 2007 | 07:37 AM
lunch_box_4_life's Avatar
Default compression
what is the most compression i can run safely in pump gas
in a d16z6
Old Aug 22, 2007 | 08:05 AM
91hybridDX's Avatar
I'm assuming your about to build a z6? it depends on whether your doing a turbo or n/a set-up
Old Aug 22, 2007 | 11:08 AM
ddd4114's Avatar
Default Re: compression (lunch_box_4_life)
There are a lot of variables...
You'll have to describe your setup (or intended setup)...
Libertariat's Avatar
Ek Forever y0!
Default Re: compression (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">There are a lot of variables...
You'll have to describe your setup (or intended setup)...</TD></TR></TABLE>
Yes, too many.
Old Aug 22, 2007 | 12:39 PM
Boost_V's Avatar
Default Re: compression (ek forever guy)
boost= low comp. pistons
na= don't even bother
Old Aug 22, 2007 | 12:40 PM
EJ1chevelle's Avatar
Default Re: compression (Boost_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_V &raquo;</TD></TR><TR><TD CLASS="quote"> boost= low comp. pistons
na= don't even bother</TD></TR></TABLE>
NA builds are fun but you get alot less power for alot more money than a turbo.
Old Aug 22, 2007 | 12:45 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_V &raquo;</TD></TR><TR><TD CLASS="quote">na= don't even bother</TD></TR></TABLE>
You need compression for any decent N/A build...
Old Aug 22, 2007 | 01:29 PM
Boost_V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egB16A &raquo;</TD></TR><TR><TD CLASS="quote">
NA builds are fun but you get alot less power for alot more money than a turbo.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">
You need compression for any decent N/A build...</TD></TR></TABLE>
Not on a D series, that's for sure.
Old Aug 22, 2007 | 02:37 PM
na setup has to be built i was going to
rebuild my daily driver i just want a little more power need the pistons anyway
probly going to bore over 1mm
Old Aug 22, 2007 | 04:02 PM
Boost_V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunch_box_4_life &raquo;</TD></TR><TR><TD CLASS="quote">na setup has to be built i was going to
IMO, if you're going through the trouble to build it, then boost it.
Old Aug 22, 2007 | 07:44 PM
doood's Avatar
been there done that
12:1
that was easy
Old Aug 23, 2007 | 01:31 PM
so what piston's will get me close to 12:1
Old Aug 23, 2007 | 01:40 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunch_box_4_life &raquo;</TD></TR><TR><TD CLASS="quote">so what piston's will get me close to 12:1
Some aftermarket pistons or civic gx pistons.
SilverWarrior
Mar 31, 2008 11:39 PM
M.A.R.C.
Apr 12, 2006 02:15 PM
95BlkGSR
Oct 26, 2004 08:15 PM
TyPe-R6
Aug 31, 2004 06:40 PM
Soon_2b_evil
Oct 9, 2003 06:25 AM
