Gas Tank noise?!?!?!?
Old Jun 13, 2002 | 12:53 PM
d357r0y's Avatar
Default Gas Tank noise?!?!?!?
Has anyone here had a problem with their fuel tank making a rattling noise?
mine seems to be only when i start off in 1st gear or going around a corner under 15mph.
i already tightened the straps
any suggestions?
Old Jun 14, 2002 | 04:12 PM
d357r0y's Avatar
Default Re: Gas Tank noise?!?!?!? (d357r0y)
TTT
Old Jun 14, 2002 | 10:21 PM
OldSchoolHatch's Avatar
I know you want to bring your post to the top, but what does "TTT" mean? Sorry but I can't help you with the gas tank noise, but I was just wonderin about that.
Old Jun 14, 2002 | 10:23 PM
No More Civic's Avatar
Default Re: Gas Tank noise?!?!?!? (OldSchoolHatch)
TTT = To The Top.....as for the fuel tank noise, are you sure the tank it's self is tight? Or maybe your fuel pump came loose?
Old Jun 15, 2002 | 06:03 AM
d357r0y's Avatar
Default Re: Gas Tank noise?!?!?!? (SlowCivicDX)
possible, but i took the tank down to see if repositioning it would help and when i did that i disconnected and took out the pump.. i was thinking it might be the anti-vibration pads on top of the tank but they all seem soft still. if it keeps up i suppose ill try a bicycle innertube on top of the tank between the body.
but i will check the pump again.
Old Jun 15, 2002 | 06:08 AM
EF_LSVtec's Avatar
There is a metal shield between your tank and exhaust pipe...you may not notice it touching expecially when your car is jacked up, but when it's on all fours, it can possibly rub. The catalytic too is another possibility. Is it rattling on idle or only when you're driving?
Old Jun 15, 2002 | 07:21 AM
d357r0y's Avatar
Default Re: Gas Tank noise?!?!?!? (EF_LSVtec)
only when i drive..and it seems to be only in first gear or going around a corner slowly.
i had taken the tank down once and it seemed to fix it but its back.. i think what originally caused the noise was the right rear tire started to get a welt in it and had massive vibrations.. so its possible something inside the tank is loose.
Old Jun 15, 2002 | 08:07 AM
kyler's Avatar
whats it sound like? clunking? squeaking? If you have poly bushings or coilovers that could possibly be it as well... they should really make a USB sound recorder so we can hear these things
Old Jun 15, 2002 | 08:15 AM
crx(gator)'s Avatar
i have the same rattling i think as you, like only when its at idle, but once i rev it it goes away, mine is hte muffler rattling, i still havent fixed it though...have someone sit in the car and have the car at idle and hold the muffer with your foot and see if the rattling stops...
Old Jun 15, 2002 | 08:52 AM
d357r0y's Avatar
Default Re: Gas Tank noise?!?!?!? (crxgator)
its not the muffler.. the noise was there before i had a new cat back put on..
plus, when i had the entire rear out of the car, i was hitting where the tank is and it was rattling.
i originally put some rubber under the straps between the tank..but its not taking up enough slack..
i guess im just going to have to drop the tank again and put up some rubber on top
swizz977
18
Aug 1, 2011 06:51 AM
aasaa666
Dec 27, 2007 03:23 PM
DumpedSi
Aug 14, 2003 01:30 PM
GruvyTune
Aug 15, 2002 05:10 AM
HondaCivicEx98
Jun 2, 2002 07:18 PM
