what is the difference with the f23 & the h22 crank?
Old Aug 21, 2007 | 07:22 PM
projectef's Avatar
Default what is the difference with the f23 & the h22 crank?
i was jus wondering what is the difference between the f23 & the h22 crank.
people say its better, so what is really better?
Old Aug 22, 2007 | 03:48 AM
PirateMcFred's Avatar
Default Re: what is the difference with the f23 & the h22 crank? (projectef)
The F23 has 6.7mm more stroke.
More displacement, more torque, more power.
Old Aug 22, 2007 | 04:42 AM
alterdcreations's Avatar
Default Re: what is the difference with the f23 & the h22 crank? (PirateMcFred)
also seems that the f23 crank is a more stout peice with the 55mm mains
Old Aug 22, 2007 | 11:12 AM
projectef's Avatar
so if i use the f23 crank in the h22 block i still can use the h22 pistons & rods right? and gain a lil more power
Old Aug 22, 2007 | 11:25 AM
Default Re: (projectef)
nope
f23 crank and rods with h22 pistons(they will stick out of the hole) or f20c(s2000)perfect fit
Old Aug 22, 2007 | 11:36 AM
projectef's Avatar
so f23 crank & rods w/h22 pistons or s2000's. whats good about the s2k pistons, i didnt know u could do that.
Old Aug 22, 2007 | 11:41 AM
the h pistons will stick out. it will work but you will need a thicker headgasket of recess your combustion chambers
the f20c pistons(s2000) will be a perfect fir and you can use your stock headgasket
check out pirate's thread^
Old Aug 22, 2007 | 11:52 AM
projectef's Avatar
what is the compression ratio for the s2k pistons?
Old Aug 22, 2007 | 03:48 PM
machine4321's Avatar
yea id liek to know as well .
i suck at math
96ekdowork
Aug 1, 2011 06:51 AM
Navy_CRX
Jul 6, 2010 02:25 PM
michaelprice83
Feb 16, 2009 09:27 AM
drift4jesus
Apr 18, 2006 12:59 PM
honda13typer
Apr 27, 2004 10:04 AM
