ok so WTF...
my crx will run fine for a while ill go some where get out and when i come back it will act like there is a dead battery like the clicking sound, i check all the terminals etc, and nothing still the click, i remove the carpet by the ecu and i wiggle the wires and tap on the ecu and it will try and start but then nada ill click the key on and off then it will run but throw a code for a LONG 7 and a short 3 i disconnected the battery for 30s start it back up still dont wanna run try again starts but wont idle i have to keep it rev'ed up then shut it off and try again, starts right up no cel and no codes WTF. This is on a chipped obd0 b16.
what was it chipped with? Are you using BRE? IF you are thats your problem. I went through 2 ecu and a dizzy before I figured out bre is full of bugs and does not work right. I swapped in a stock ecu and the clicking went away. I just converted to obd1 to tune properly
i believe its the same as this
http://cgi.ebay.com/A-SPOON-EC...wItem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson »</TD></TR><TR><TD CLASS="quote">Get rid of the chip.
Other than that, sounds like the main relay to me... is it getting fuel when it wont start?</TD></TR></TABLE>
x2
Those eBay chips are bad news.
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
x2
Those eBay chips are bad news.</TD></TR></TABLE>
X eleventy jillion.
Throw that useless **** in the garbage and go back to stock and have someone
that knows what they are doing tune it.
x2
X eleventy jillion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrxb16 »</TD></TR><TR><TD CLASS="quote">what makes them so bad...... </TD></TR></TABLE>
Because they're mass-produced and bootleg. Tuning should be done on a one-off basis, not every tune will work for every vehicle, even if they are similar setups.
TexasRoller
Aug 15, 2012 04:38 PM
HamiltonRex
Jul 10, 2004 01:02 PM
xenocron
Jan 2, 2004 07:38 PM
hahahahhah
18
Feb 13, 2003 10:59 PM
