fan not working, checked usual stuff
Old Aug 21, 2007 | 01:13 PM
vti444's Avatar
Default fan not working, checked usual stuff
basically never kicks in
tested fan and works fine, fuse is fine, new fan switch fitted and tried paperclip in fan switch conncetor but still doesnt kick in
apart from relay (ill have to get this tested but dont think its that) and bad connection is there anything else that could be cause ?
Old Aug 22, 2007 | 08:24 AM
vti444's Avatar
Default Re: fan not working, checked usual stuff (vti444)
help, temps can get very high in at idle and when pushed hard so need the fan working
Old Aug 22, 2007 | 08:29 AM
crazyguy's Avatar
could be the bad Thermostat
Old Aug 22, 2007 | 08:39 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: fan not working, checked usual stuff (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">could be the bad Thermostat </TD></TR></TABLE>
Could be, but! If your jumping the fan with the paper clip it should work regardless. Is the key turned all the way to ON? If this is not working check all your wires going to the fan. Maybe there cut and got wet or something. Give her a check.
Old Aug 22, 2007 | 08:49 AM
vti444's Avatar
Default Re: fan not working, checked usual stuff (HondamanXxX)
yes key is fully turned, thermostat is fine and heats up completly normal and have water temp gauge so know fan should be on with temps im seeing, fan should kick in much earlier now though as mugen fan switch fitted
i cant see any bad conncetion so guess ill have to get someone with tester to check wiring to find bad connection
Old Aug 22, 2007 | 08:51 AM
GO GIANTS!
Check them wires! Good luck man.
apexi_rsx
Jul 19, 2013 07:43 PM
jlowellintegra
May 30, 2011 07:52 AM
Eglifestyle
10
Mar 23, 2008 12:08 PM
Paluce
Mar 20, 2007 09:33 AM
ViXoN Hatch94
Feb 4, 2006 07:53 PM
