vtec not working
Old Jun 13, 2002 | 10:57 AM
22civic's Avatar
Default vtec not working
hi i have a 92 hatch with a h22 and i cant get the vtec to pop. it does it sometimes but then it doesnt work anymore. im only getting the code 4 the crank angle sensor and the 02 sensor. we used a 95 gsr engine harness to replace the vx harness. i dont know why it is not working. if anyone can help please do
Old Jun 13, 2002 | 11:46 AM
B16C-RXed's Avatar
Default Re: vtec not working (22civic)
Check your VTEK switch yO! Seriously it might have gotten corroded by oil or something when you did the swap. Just clean it out real good, and if that isn't it then you have a bad wire somewhere...VTEC is all electrical, so if it doesn't work then you are screwed... also, if it isn't letting you rev above 3500 rpms then you know it is the VTEC, but if you just feel slow then the vtec is engaging, it's just another problem...sorry dude.
So drive it down the block about half throttle, allow it to go through all the rpms, you will feel about 4 or 5 pops, as you call them...if you don't then I don't know what it could be...but I am pretty sure that if VTEC isn't engaging then you shouldn't be able to rev over 4grand for sure. Also, CHECK ALL OF YOUR GROUND WIRES, that really f*U*C*K*S* you...hehe...sorry again dude. L8
Old Jun 13, 2002 | 11:51 AM
Kamin's Avatar
Default Re: vtec not working (B16C-RXed)
Ok, I have noticed ALOT of people recently asking about why their vtec isn't working. I'm just going to do some of the basic steps in checking to see why the **** vtec isn't working .
1) Oil level, its gotta be FULL. I'm talking at the upper mark on the dipstick.
2) Solenoid, Ok this is a 2 parter. A) take a wire (any wire) disconnect the grey plug on the vtec solenoid and touch the wire to the pos. battery terminal and the solenoid side of the grey 1 pin connector. there should be an audible click from the solenoid. B) If A checks out, remove the solenoid and clean the filter screen. (self explanatory)
3) Speed, the car must be going over 10 mph so the spedo must be working. that means the VSS has to be working. vtec is temperamental isn't it?
4) more oil, check the oil pan. if its dented POUND IT OUT!. this is why mine wasn't working. the pan was dented in far enough to hit the oil pickup for the pump to cause low pressure situation in the head, no pressure no vtec.
5) ECU Swap out to another ECU that you KNOW vtec works on.
6) Car must be at I belive its 80 degrees or higher so let car get to a normal operating temprature.
7) If none of the above work, you might want to pull the solenoid off the head, remove the solenoid filter and verify the piston moves freely.
Thats a basic troubleshoot for it. if i missed anything or got anything wrong just reply and ill change the info.
If you go through all this and it still doesn't work its oil pressure (the pump) or wiring related. so check all the wires for vtec.
Thats it i hope it helps some people.
Joe
good luck!
https://honda-tech.com/zerothread?id=164863
Old Jun 13, 2002 | 12:07 PM
22civic's Avatar
thanks ill try rhem and let u know whats up
Old Jun 13, 2002 | 01:02 PM
B16C-RXed's Avatar
Good luck, that was what was up with mine, when I pulled the head for some work, I got oil all up inside of the switch assembly...sucked, but easy to clean and fix...definetly check your GROUND WIRES>>>
smurfylee
22
Sep 26, 2008 01:54 AM
t-dizzy
May 18, 2008 01:44 PM
civicx
12
Aug 25, 2005 06:44 PM
jojovtec
Dec 19, 2004 08:44 PM
