Leak Somewhere?
well my car is leaking..but i checked the oil pan and it wasnt oil, checked my transmission..not leak there either..
but theres this one spot where its commin from and its connected to the axle from the trans to the axle...its leaking from there but not to sure how to fix it...anyone knows?
ill post soon
ill post soon
i dunno if you changed your axles lately but it sounds like you are missing the ring at the end of the trans side of your axle. go under your car and see if you can slide your axle back and forth. if you can the axle isnt clicked in. are you leaking trans fluid or oil. if its trans fluid it will stop after it gets to a certain level.
peekeesh
18
May 1, 2010 01:21 PM
gsxr1k05
11
Mar 2, 2009 01:33 PM
