hissy noise
i am driving my step dads 95 accord its an F22B2 i think is what the stamp said... anyway im going 70 on the highway all the sudden the car starts making a hissy sounds but its only when i press down on the gas.... if im coasting it doesnt make the sound... if i am sitting at a stop light in neutral and rev the car it does make the sound.... i believe the noise is coming from the internals of the car but i am trying to get a better idea..... its takes about 30 seconds to get to 60mph now by the way... please someone give some advice
yes its an automatic and the vehicle was perfectly fine before i dont see any problems with the transmission atleast it is shifting fine
WHENS THE LAST TRANSMISSION FLUSH DONE, THE REASON WHY I SAY THIS IS BECAUSE I SEEN AN 03 ECLIPSE HISSY WHEN U GIVE IT ABOUT 1/2 GAS PEDAL IT WOULD HANG AROUND 4000 RPMS, BUT IN NEUTRAL WAS FINE, IT SHIFTED FINE TOO, TRY SLAMMIN THE GAS TO THE FLOOR AND SEE IF IT HANGS ON ANY RPMS, A TRANSMISSION FLUSH FIXED THE PROBLEM ON THE ECLIPSE, CHECK YOUR FLUID. YOU NEED TO DO A TRANNY FLUSH EVERY 60K MILES ANYWAYS.
so i took the car to a service station and they told me that my timing belt skipped 2 links.. and when the car is running and i take the oil cap off there is lot of air blowing out... any ideas
a bad tensionr could cause it to skip, but that would give problems threw the whole driveing range, and would back fire at idle if you dont advance the timeing all the way. never heard a hissing sound from a timing belt skiping.
gators113
Transmission & Drivetrain
Jun 24, 2019 02:51 PM
HondaScott
Honda Civic (2001 - 2005)
15
Nov 28, 2008 10:55 AM
BnEiAkUiTcY
15
May 30, 2002 09:34 AM
