Idle vacuum psi went up, should I be worried?
Old Aug 20, 2007 | 01:29 PM
mengy007's Avatar
Default Idle vacuum psi went up, should I be worried?
When my engine is at idle my vacuum is around -12psi it used to be around 19psi. Should I be worried? Could moving my distributor cause this?
Old Aug 20, 2007 | 01:32 PM
rdssk8rcs1's Avatar
Default Re: Idle vacuum psi went up, should I be worried? (mengy007)
Depending how much you moved the distributor? Moved it enough to make it run rough? Its definitly something i would be worried about depending on what it was before? Did it happen all of a sudden?
Modifications like lumpy cams will cause something like this but other than that thats a very high (lesser pressure) level of vacuum.
Old Aug 20, 2007 | 01:54 PM
mengy007's Avatar
Default Re: Idle vacuum psi went up, should I be worried? (rdssk8rcs1)
well i had to remove the distributor cuz I was installing a new Trans. After I put everything back on, I noticed that there was a leak on my wastegate so I fixed it. No new cams, didn't mess with timing belt. my idle is higher now, might be my throttle cable or something rather.
Old Aug 20, 2007 | 01:58 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mengy007 &raquo;</TD></TR><TR><TD CLASS="quote"> my idle is higher now, might be my throttle cable or something rather.</TD></TR></TABLE>
i think you just answered your own question.
Old Aug 20, 2007 | 02:49 PM
mike93eh2's Avatar
might be vacuum leak.
Old Aug 20, 2007 | 09:56 PM
mengy007's Avatar
Default Re: (mike93eh2)
I checked all my vac lines when I got home from work. Turns out the line to the side of my TiAL WG had a leak. I fixed it and my car is at normal idle and vac
Old Aug 21, 2007 | 01:06 AM
quicksilver1689's Avatar
i ♥ snails
yay!
cjwang2
Jun 30, 2014 07:43 AM
crxsiperf
Aug 13, 2006 09:17 PM
SwappedLSHatch
Apr 6, 2006 04:33 PM
egCoupe
10
Aug 12, 2005 12:54 PM
headhunter
Aug 18, 2003 08:14 PM
