B16A
Old Aug 20, 2007 | 11:05 AM
Xathine's Avatar
Default B16A
Worth it for a complete swap? All I can afford, and I'm afraide if I save up i'll end up dumping the extra into suspension / etc enstead of going for a higher swap
Driving a 96 sol bone stock (D16Y7) , no plans to boost.
EL Vap133's Avatar
Default Re: B16A (Sol.Taker)
Major difference from the y7 to the B16a.
Old Aug 20, 2007 | 11:13 AM
Xathine's Avatar
Default Re: B16A (EL Vap133)
Noticeable for a DD?
Or just at higher RPMS?
Old Aug 20, 2007 | 11:14 AM
highrev1987's Avatar
you will notice the difference more in the mid to high rpms but down low it will feel the same and still get great MPG
Old Aug 20, 2007 | 11:24 AM
Xathine's Avatar
And if I was going to get one from HMO.com which one should I ****** up?
And they come with everything right? So I could just take it to a shop and pay someone to drop it in for me and be good to go?
Should I upgrade / improve anything else before I swap? Car is bone stock.
Old Aug 20, 2007 | 11:29 AM
97Ej6mike's Avatar
Yes, Hmotors will provide you with everything you need, just make sure you read the print of whats included, just to make thing clear.
Remember
Motor *(complete with sensors and mounts, ect)
trans*
Linkage*
Wiring harness (for LHD car) *
ECU*
In my opinion, you may get a better experience out of it all by investing in hasport (or any other company) mounts, and it would be wise to buy a new clutch for it before its all swapped in. Either OEM or upgraded would be fine.
Old Aug 20, 2007 | 11:50 AM
Xathine's Avatar
Default Re: (97Ej6mike)
Cool thanks, yeah if I get a package from HMO i'll upgrade the mounts and LSD tranny and all that other stuff they offer
but pre-swap anything I should do?
Old Aug 20, 2007 | 12:53 PM
instrument's Avatar
if you have a garage i'd highly advise saving the money to pay a shop to do it, and invest in some tools and do it yourself.
i'd change the timing belt/water pump, while the motor is out, along with the clutch.
honestly swapping a motor isn't very hard.
goodluck
Old Aug 20, 2007 | 08:41 PM
97Ej6mike's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">honestly swapping a motor isn't very hard.
goodluck</TD></TR></TABLE>
Sometimes, lol.
Old Aug 20, 2007 | 08:45 PM
speedooo's Avatar
swapping a motor is easy if you arent dumb about it. if you think logicaly about its just some bolts fluids and plugs
Old Aug 20, 2007 | 09:51 PM
forcefedferio's Avatar
Default Re: (speedooo)
yeah and so long as nothing unexpected goes wrong
qtk20
Apr 13, 2011 08:55 AM
Tru Dynamix
18
Sep 13, 2002 06:33 AM
infamousALLMTR
Feb 27, 2002 03:36 PM
hondaspeed
Dec 28, 2001 05:28 PM
Jaysmy
10
Aug 18, 2001 12:49 PM
