VTEC??
Old Aug 20, 2007 | 10:45 AM
92yellowEG's Avatar
Default VTEC??
I got a 1.5L that finally craped out and I ordered a JDM 1.5 VTEC with 46,000 miles to replace it.
I was told that it will work perfectly with no modifications if you had the 1.6 vtec or SI but I don't and was wondering first off what ECU will I need and will I need to change the harness to make it work?
Also can anyone tell me how I can make sure it is actually VTEC?? I've never had one and don't know what to look for but all the 1.5 VTEC engines don't seem to say so on the valve cover and anyway it's just a valve cover so it's easy to change!
The engine is suppose to be here in the next 2-3 hours so PLEASE help!!
Old Aug 20, 2007 | 10:52 AM
instrument's Avatar
OMG
you can tell it's a vtec because of the magial vtec nipple on the left of the valve cover.
but you don't really know what that is soo
and if the motor will be there in 2-3 hrs, i think it's a little late to be shopping for the correct ecu, don't you?
Old Aug 20, 2007 | 10:54 AM
Syndacate's Avatar
Default Re: VTEC?? (92yellowEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92yellowEG &raquo;</TD></TR><TR><TD CLASS="quote">I got a 1.5L that finally craped out and I ordered a JDM 1.5 VTEC with 46,000 miles to replace it.
The engine is suppose to be here in the next 2-3 hours so PLEASE help!! </TD></TR></TABLE>
There will be a VTEC solenoid. It's a funny shaped thing with a greenish cylindrical top on the left side of the engine (when looking at it from the front) right next to (closer to the firewall) the distributor.
As for alterations, you need to wire up the VTEC solenoid wire and the VTEC spool oil pressure check sensor - 2 wires, go into I think A4 and D6 (respectively) on the back of the ECU. Just wire them directly, it's two wires, don't bother buying an EX harness or some stupid crap like that, just wrap them in wire wrap or something.
Here's what the solenoid looks like:
NOTE: It's on the other side of the distributor (closer to the firewall) on a D15
Here's a JDM D15B
Right under the valve cover breather you can see it. It has a big green plug on it too (oil pressure check).
Hope that helped some.
Old Aug 20, 2007 | 11:01 AM
92yellowEG's Avatar
Yes that helps very much, thank you! Also "instrument" I didn't say I was putting it in the car in 2-3 hours I just wanted to make sure they delivered the correct engine! Thanks for the reply anyway, So is it the P28 ECU that should be used?
I have a P05 in the car and a PM5 lying around but I know those won't work. So which ECU is needed?
Old Aug 20, 2007 | 11:09 AM
S2blueeg's Avatar
rookie!
Old Aug 20, 2007 | 11:11 AM
speedooo's Avatar
Default Re: (92yellowEG)
p08
Old Aug 20, 2007 | 11:35 AM
92yellowEG's Avatar
Default Re: VTEC?? (S2blueeg)
seriously why even post that!! I'm pretty sure it's very clear that I have no experience with honda's but thank you Captain Obvious for that helpful comment!
Old Aug 20, 2007 | 11:38 AM
92yellowEG's Avatar
Default Re: (speedooo)
so speedooo P08? I've been told to use P06, P28, but I don't know so thanks
big-cat's Avatar
here is a weird question. i wonder i fyou could make any honda or even any car for that matter vtec, because (i dont remember what it all stands for) but basically doesnt it shoot oil into the head or am i just retarded?
Old Aug 20, 2007 | 01:04 PM
92yellowEG's Avatar
Default Re: (big-cat)
Interesting, never thought of it like that. It's probably like ford's ZTEC.
Old Aug 20, 2007 | 01:10 PM
blk92_d16's Avatar
^Ah, that'd be a no on the VTEC for everyone concept. LOL
You can use a converted P06, P07, P08, and the good 'ol P28...and I'm sure there are others too!
Old Aug 20, 2007 | 01:16 PM
92yellowEG's Avatar
Default Re: (blk92_d16)
Thanks for the feedback, also does anyone know the code for manual on the ECU?
for example if you had a P 28 (manual) what would the rest of the code look like? thanks,
Old Aug 20, 2007 | 01:31 PM
95ej2's Avatar
if you dont want to get a chipped ecu then you can get either a p28 or a p08. either one will be fine.
kixcrx
Jan 18, 2007 06:27 AM
Didly
20
Nov 23, 2005 07:49 PM
JDMB18CEJ1
Jul 28, 2004 07:30 PM
youngwon22
Oct 5, 2003 09:54 PM
bad93ex
Jul 26, 2002 11:37 PM
