Hondata S200B vs. Hondata Stage 4 w/Boost **Which System???**
Old Aug 20, 2007 | 08:17 AM
spoonhatchblack's Avatar
Default Hondata S200B vs. Hondata Stage 4 w/Boost **Which System???**
Well I'm debating weather to go w/the Stage 2 or 4 Hondata for my next F/I Tune or Should I settle for the S200B (I ran this system before )
Tell me the Pros & Cons (If any) of the 2-Systems?
Old Aug 22, 2007 | 11:21 AM
99blusi's Avatar
Default Re: Hondata S200B vs. Hondata Stage 4 w/Boost **Which System???** (spoonhatchblack)
Stage 4 is dated...the only way you're going to find one of those is used.
s200 is capable...but burning chips blows
s300 is cheap, faster and has boost control
Old Aug 22, 2007 | 11:38 AM
mtber's Avatar
Default Re: Hondata S200B vs. Hondata Stage 4 w/Boost **Which System???** (99blusi)
Just go to s300 if your buying a new system
Old Aug 22, 2007 | 11:49 AM
mike1114's Avatar
Default Re: Hondata S200B vs. Hondata Stage 4 w/Boost **Which System???** (mtber)
I was going to disagree and say get the older system but when thinking about it, once you buy the s200 and then get a boost controller also, you've already spent what the S300 costs.
Old Aug 22, 2007 | 05:35 PM
Default Re: Hondata S200B vs. Hondata Stage 4 w/Boost **Which System???** (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">I was going to disagree and say get the older system but when thinking about it, once you buy the s200 and then get a boost controller also, you've already spent what the S300 costs.</TD></TR></TABLE>
So the S300 comes w/Internal Boost Controller??? Or you would have to add it in additional when you purchase the S300?
Old Aug 22, 2007 | 07:04 PM
TsujenDB1's Avatar
it comes with it
Old Aug 22, 2007 | 10:46 PM
locash's Avatar
The S300 supports boost control if you add in a few extra components to the ecu, and pick up a GM solenoid (under $50 for the solenoid and harness)..
Old Aug 23, 2007 | 12:10 AM
mtber's Avatar
Default Re: (TsujenDB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TsujenDB1 &raquo;</TD></TR><TR><TD CLASS="quote">it comes with it </TD></TR></TABLE>
Incorrect. The s300 system has an optional pwm boost package to install into the ecu. You will then need a GM boost solenoid w/ pigtail to control your boost via the hondata s300 system.
Old Aug 23, 2007 | 08:40 AM
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Incorrect. The s300 system has an optional pwm boost package to install into the ecu. You will then need a GM boost solenoid w/ pigtail to control your boost via the hondata s300 system.</TD></TR></TABLE>
How much EXTRA $$$ would it cost to add the PWM on top of the s300??? (if you already have the GM Boost Solenoid and Pigtail.)
Old Aug 23, 2007 | 01:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonhatchblack &raquo;</TD></TR><TR><TD CLASS="quote">
So the S300 comes w/Internal Boost Controller??? Or you would have to add it in additional when you purchase the S300?</TD></TR></TABLE>
it is a few bucks to add the components yourself, or pay hondata like 75 to do it, and from there it is all in the software. i kinda like it. it is like 200 tops. i cant remember how much hondata wanted to prep the ecu, and you can use an AEM solenoid or a MAC valve. you just need to invert the polarity in the boost control parameter.
Old Aug 23, 2007 | 02:11 PM
PrecisionH23a's Avatar
S300 all the way.... to add the components it's only another $60 bucks. The gm solenoid is also around $50.
i3oricua
Jul 5, 2003 10:23 PM
