Electrical Problem Help!
im having some problems with my wiring
i have an eg coupe (dx) with a b16a2
nothing is getting power
battery is fine but nothing so could my grounds be causing this?
very possible, check for voltage on ground side by putting black lead on negitive post of battery and then red lead on ground wire. both wires will be on ground side but if you see voltage on the ground wire then its a bad ground.
ill try that also in the harness i think i may have over looked a ground
what all ground wires do i need to have?
im using a del sol harness that i spliced to make
Well of course you have three main ones Battery ground, trans ground, and ground coming off of valv cover or driver side of engine.
then you should have at least two (look like little boxes with wires coming out of it) near front and both sides of engine bay these will be various grounds for all other things but there maybe more that is just what I know as far as how many and where. all the wires that come out of it are black
94EGKUSH
16
Mar 17, 2009 05:54 PM
SlowPokeEg
Apr 15, 2008 10:29 AM
