p28 or p72 ?
Old Aug 19, 2007 | 11:09 PM
civicb16eg's Avatar
Default p28 or p72 ?
what ecu should i run on my gsr i/h/e swapped 99 civic?
Old Aug 19, 2007 | 11:15 PM
xjosfx's Avatar
I LIVE IN
well i know the p28 is what i have on my 97 EX, so i dont think that would help you much. maybe the p72 would be better.
Old Aug 19, 2007 | 11:40 PM
Quiks66's Avatar
Default Re: (xjosfx)
P28 ECU's are made for SOHC Vtec, not DOHC. You can use a P28 ECU that is chipped to run DOHC, but it's better to use a stock DOHC GSR P72 to start and then mess with fuel mapping later on. Do some research!
Old Aug 20, 2007 | 06:17 AM
h22a1_julien's Avatar
Default Re: p28 or p72 ? (civicb16eg)
chip your P28 ....healthy enough
Old Aug 20, 2007 | 06:21 AM
speedooo's Avatar
Default Re: p28 or p72 ? (h22a1_julien)
if it aint broke dont fix it...use a p72.
Old Aug 20, 2007 | 06:23 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: p28 or p72 ? (speedooo)
You're motor is stock. use the stock ecu.
Good rule of thumb.
Old Aug 20, 2007 | 06:25 AM
sicones's Avatar
Default Re: p28 or p72 ? (ek forever guy)
if you want to pass emissions = OBD2A P72
if you want to fall emissions, chip it, and tune the car = P28
I have both
Old Aug 20, 2007 | 06:31 AM
Ek Forever y0!
Default Re: p28 or p72 ? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">if you want to pass emissions = OBD2A P72
I have both </TD></TR></TABLE>
My brother has the same setup for when emissions makes its way to our little town.
Come test time he just pops on the stock ecu. After, he puts back on the hondata.
Old Aug 20, 2007 | 06:59 AM
speedooo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Come test time he just pops on the stock ecu. After, he puts back on the hondata. </TD></TR></TABLE>
i use a p05 for inspection. it was my stock ecu for the 1.5 8v...it only looks for 1 wire o2 and eliminates practicaly all cel's
93bubble87
Engine Management and Tuning
11
Jan 5, 2010 07:59 PM
MOVE OVER
Sep 6, 2007 08:59 AM
GDM93Si
12
May 9, 2006 01:58 PM
Zion-I
Feb 12, 2006 09:32 PM
u2civic1
Apr 1, 2003 09:54 AM
