HOW TO MAKE POWER WITH A D16Y7
Old Aug 19, 2007 | 09:52 PM
d16spooler's Avatar
Default HOW TO MAKE POWER WITH A D16Y7
SOOO.......going from my last thread on.........where can i get a y8 head and intka emanifold......and also if the y8 is vtec....do i need a new e.c.u. n other stuff? or what?
Old Aug 19, 2007 | 09:55 PM
Syndacate's Avatar
Default Re: HOW TO MAKE POWER WITH A D16Y7 (d16spooler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16spooler &raquo;</TD></TR><TR><TD CLASS="quote">SOOO.......going from my last thread on.........where can i get a y8 head and intka emanifold......and also if the y8 is vtec....do i need a new e.c.u. n other stuff? or what?</TD></TR></TABLE>
You do need a new ECU to make VTEC work, although your best bet is to get a tunable ECU and get it tuned.
For the Y8 head/mani check craigslist, ebay, and the H-T marketplace.
Yes, the Y8 head is VTEC.
You can use the P2P ECU but I'd get a chipped OBD-I and run that off a good tune for optimal performance.
EDIT:
PS: You need to wire up VTEC and the VTEC spool pressure check switch - there's a how-to on it here:
https://honda-tech.com/zerothread?id=735196
Should be everything you need.
Ekevans08
Dec 12, 2012 06:11 AM
chickenwing
Oct 26, 2008 05:05 AM
assassinACE12
Oct 24, 2007 01:32 PM
feriob12
Nov 22, 2003 10:20 PM
