HOW TO MAKE POWER WITH A D16Y7
SOOO.......going from my last thread on.........where can i get a y8 head and intka emanifold......and also if the y8 is vtec....do i need a new e.c.u. n other stuff? or what?
Re: HOW TO MAKE POWER WITH A D16Y7 (d16spooler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16spooler »</TD></TR><TR><TD CLASS="quote">SOOO.......going from my last thread on.........where can i get a y8 head and intka emanifold......and also if the y8 is vtec....do i need a new e.c.u. n other stuff? or what?</TD></TR></TABLE>
You do need a new ECU to make VTEC work, although your best bet is to get a tunable ECU and get it tuned.
For the Y8 head/mani check craigslist, ebay, and the H-T marketplace.
Yes, the Y8 head is VTEC.
You can use the P2P ECU but I'd get a chipped OBD-I and run that off a good tune for optimal performance.
EDIT:
PS: You need to wire up VTEC and the VTEC spool pressure check switch - there's a how-to on it here:
https://honda-tech.com/zerothread?id=735196
Should be everything you need.
EDIT:
Ekevans08
12-12-2012 06:11 AM
feriob12
11-22-2003 10:20 PM
