Balancer shaft belt tension? I think it's too loose -pic inside-
2001 accord 4cyl MT
I put back my timing belt and balancer shaft belt together and 'auto' adjusted the tensionners. (i may replace them tomorrow if i got enough $$ if not in about 2 weeks)
The thing is that my timing belt was correctly tensioned, but my balancer shaft belt seems a bit loose... Here's pics to give you an idea.
here's how it looks like if i push on it with moderate pressure
I'll try messin around with it tomorrow see if i can get more tension out of it (this being if i cannot afford new parts..)
BTW, i cleaned everything, lubed the springs to make sure they operated at their best, and everything (timing marks) all align perfectly..
Any ideas?
thanks!
Any ideas?
thanks!
