Clutch help on eg
Old Aug 19, 2007 | 04:38 PM
T Rick's Avatar
Default Clutch help on eg
i put the car in gear and let the clutch out slowly and it doesn't ingage. so i blead my clutch but that didn't help????????
Old Aug 19, 2007 | 04:49 PM
hondastreets1's Avatar
Default Re: Clutch help on eg (T Rick)
may be broken axle
Old Aug 19, 2007 | 05:21 PM
T Rick's Avatar
Default Re: Clutch help on eg (hondastreets1)
wouldn't it one catch
T Rick's Avatar
wouldnt one catch********
Old Aug 19, 2007 | 05:23 PM
lsdB16aEj1's Avatar
have you messed with your pedal assembly at all, because i did that once and had problems with my clutch
Old Aug 20, 2007 | 07:24 PM
T Rick's Avatar
Default Re: Clutch help on eg (lsdB16aEj1)
i dont know what that means someone help out please!!!
Old Aug 20, 2007 | 07:29 PM
hondamark35's Avatar
put the car in gear and jack it up on both sides in the front. turn one wheel and if the other one spins (the opposite direction) then you need a new clutch. if the other wheel doesn't spin then you need to find out which axle you broke.
oh and to make sure your pedal is working, pull the boot back from the clutch fork (this is the boxy looking black rubber thing next to the slave cylinder on the front side of the transmission), and have a friend watch the fork and slave to make sure they move when you move the pedal up and down.
Old Aug 20, 2007 | 11:30 PM
lillthingz's Avatar
What does it do exactly? I had that happen to me a few years ago and it was the slave clutch cyl. the master one would push the fluid out, but it wasn't working on the slave cyl. Oh but my clutch pedal fell strait to the floor, and was limp.
Old Aug 20, 2007 | 11:34 PM
denraweb's Avatar
Default Re: (lillthingz)
When you push the pedal in, you will see a small rod on the slave cylinder move in and out (while pedal is being pushed/released). If you don't see this rod move, then you have a leak, or faulty clutch master cylinder/slave master cylinder. If it does move, yet the car will not move in gear still, then something internally has gone wrong.
Old Aug 23, 2007 | 06:28 PM
T Rick's Avatar
Default Re: Clutch help on eg (hondamark35)
k so i put the car on jacks and spun one wheel but the other didn't spin so that would mean axle broken but how do i know which one also on my brakes i found that the rubber boot is ripped by the cylinder(is that bad)
favd21
Transmission & Drivetrain
Sep 8, 2012 03:00 PM
hondaon18's
27
Sep 25, 2007 08:56 AM
2wheelhunter
Aug 30, 2006 07:32 PM
MniMeHatch89
Jun 13, 2006 10:48 PM
JERKthisDC2
Nov 11, 2005 07:51 PM
