do i have a sh???
Old Aug 19, 2007 | 03:28 PM
jrinehart81's Avatar
Default do i have a sh???
first off this is my first import.ive always messed with trucks butthat got old.so i have a 99 honda prelude.the engine is stamped h22a4.i want to buy a header but i need to know if its a base or sh.whats the easiest way to tell??thanks.
Old Aug 19, 2007 | 03:35 PM
117's Avatar
117
If it's an auto, it's not an SH.
Otherwise, look at your VIN. You will see JHMBB614... for a base or JHMBB615... for an SH.
You can also look to see if the door panels have lights in them. SH did, base did not.
Modified by 117 at 6:45 PM 8/19/2007
Old Aug 19, 2007 | 03:45 PM
dagle's Avatar
Default Re: (117)
really? i thought all USDM 5th gens are bb6... sh wheels/spoiler/lipkit and ATTS is how i thought u tell
Old Aug 19, 2007 | 03:50 PM
117's Avatar
117
I fixed that. All 5Gens are BB6. I don't know what the hell I was thinking.
There are tons of base models with spoilers. When my base model was a street car, I had a spoiler with the SH rear deck so there was no 3rd brake light.
The underbody spoiler was an add on. Neither the base nor the SH came from the factory with them.
You can't see if you have ATTS without getting under the car.
Old Aug 19, 2007 | 04:02 PM
ok so i cant go by the vin?its a 5 sp has a spoiler but i think someone added it cause it did have a third brake light?
Old Aug 19, 2007 | 04:23 PM
dagle's Avatar
Default Re: (jrinehart81)
wait wait wait wait.... cant u just look on ur cluster for the ATTS light?
Old Aug 19, 2007 | 04:43 PM
well when i turn the key to the on position i have no atts light.
Old Aug 19, 2007 | 04:50 PM
lude98SH's Avatar
where is the oil filter located ? Also when u go to change the oil is it open where u can get a socket on the oil pan darin plug or do u need to use a box wrench because other wise it wont clear ? Thats a sure way to also tell.
You can also look at the radiator, is there trans (in this case ATTS) cooler lines going to the bottom of the radiator ?
Old Aug 19, 2007 | 05:11 PM
Ransom's Avatar
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrinehart81 &raquo;</TD></TR><TR><TD CLASS="quote">ok so i cant go by the vin?its a 5 sp has a spoiler but i think someone added it cause it did have a third brake light?</TD></TR></TABLE>
Yes, you can go by the VIN Base model has 14 after the BB6 and the Type SH has 15 after the BB6.
But it sounds to me like a base model if you have the 3rd brake light in the back window and no ATTS light...Type SH's also come with color matched side skirts and courtesy lights on the bottom of the door panels.
Old Aug 19, 2007 | 05:41 PM
Revi's Avatar
Default Re: (LudeSH)
Just take an off ramp at 100mph. If you slam the concrete barrier you have a base, if you make it you have an SH.
J/K
Just look at you dash lights, if you dont have an ATTS light you have a base, its the easiest way. That and your door lights.
Old Aug 19, 2007 | 09:38 PM
jeremiah87's Avatar
Default Re: (Revi)
id say since you do have the car... look and see if there is what kinda i guess looks like another transmission on the back of the block, drivers side...yes? SH, no? base.
Old Aug 20, 2007 | 04:34 PM
thanks alot guys!!i do have a base model.seems like parts r a little cheaper.now need to figure out which cai and header to go with??
Old Aug 20, 2007 | 04:35 PM
dagle's Avatar
ebay CAI! kN filter
ludenoob99
Jul 13, 2007 04:09 PM
Joe...
Jul 8, 2006 05:49 AM
Steve04SVT
Oct 13, 2003 11:36 AM
UA6 BALLER STATUS
Jul 10, 2003 02:17 PM
GENERAL LEE
Mar 26, 2003 10:48 AM
